Solved K 2.0.2, K 2.0.3: problems with preview
13 years 11 months ago #138220 by freedomcoach
Sozzled, what makes you think that this blank preview issue is different from the one I've been writing about? It seems to be the same to me.
  • nant
  • nant's Avatar
  • Offline
  • New Member
  • New Member
  • Community Builder Solutions offer more for less!
13 years 10 months ago - 13 years 10 months ago #138615 by nant
Matias wrote: @demka:
According to the code Russian nicknames should display just fine if #__users and #__kunena_* tables (#_ being your prefix) are in UTF-8.
Can you check which encoding those characters are using?
Hi Matias - I also see exact same issue with Greek utf8 characters.
I also have the preview issue not working here.
Nick A. (aka nant)
CB Team member @ Joomlapolis.com
Last edit: 13 years 10 months ago by nant.
13 years 10 months ago #138935 by tekfix
I also had the problem with no preview and tried to follow the advice in this thread. No luck. I did not try to switch off the SEF URLs and rewriting as they are important.
Then I realised that Kunena has it own SEO-setting in the Configuration's General tab. "Search engine friendly URLs". It was set to "No". I changed it to "Yes" and now my previews work as they should! :blink:
Hope this information helps someone else too...
13 years 10 months ago #139245 by freedomcoach
After successfully migrating my site to a new top of the line Joomla hosting server, I discovered tonight that my forum is exhibiting the now infamous blank preview problem.
BTW, This is not the same issue I encountered before where attempting to save the post produces an error.
Now, the post seems to save fine. Its just the preview that isn't working. I checked my Kunena configuration and found that the Search Engine friendly URLs is already set to yes. All suggestions appreciated.
13 years 10 months ago #139246 by 810
Will be fixed in the new version. Soon.
The following user(s) said Thank You: roland_d_alsace
13 years 10 months ago #139552 by roland_d_alsace
810 wrote: Will be fixed in the new version. Soon.
Hi.
Effectively, the problem is solved since K 2.0.4
Thanks to the kunena's developpment team :)
