Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
16 years 11 months ago #19844 by grumblemarc
Instead of just reporting problems with HTML and CSS it would be more helpful if you can offer up a fix and post it.
16 years 11 months ago - 16 years 11 months ago #20062 by den07y
I tried Kunenalatest mod v1.0.40 and if I enable this module then I get the following error message:
Warning: require_once(componentscom_kunenalibkunena.communitybuilder.php) [function.require-once]: failed to open stream: No such file or directory in C:Program Filesxampphtdocsailesdesignesmodulesmod_kunenalatesthelper.php on line 17
Fatal error: require_once() [function.require]: Failed opening required 'componentscom_kunenalibkunena.communitybuilder.php' (include_path='.;C:Program Filesxamppphppear') in C:Program Filesxampphtdocsailesdesignesmodulesmod_kunenalatesthelper.php on line 17
I guess the module is not written for this kunena component?
Thanks in advance for your support.
Kind Regards,
Denis
Last edit: 16 years 11 months ago by den07y.
16 years 11 months ago #20065 by xillibit
From this it works only on kunena 1.0.8 : extensions.joomla.org/extensions/communi...252dons/7334/details
16 years 11 months ago - 16 years 11 months ago #20087 by jerry
Actually no, it works from 1.0.8 up... also with 1.5.1a up. Tested with 1.5.3 and works nicely.
Last edit: 16 years 11 months ago by jerry.
16 years 11 months ago - 16 years 11 months ago #20088 by jerry
Kind Regards,
Denis
Interesting. What's your platform? OS and PHP version? Kunena version?
Do you have file in components/com_kunena/lib/kunena.communitybuilder.php ? (should be there after installing kunena 1.5.3 or Kunena 1.0.10)
Do you have community builder working? Try to disable community builder in Kunena component, if the module works in that settings.
16 years 11 months ago - 16 years 11 months ago #20118 by den07y
Thanks for your message, this is my configuration and actions:
I installed the new Kunena module localy to my computer. (Before installing the module to the final web site...)
OS: Windows XP Pro
Joomla: 1.5.11
PHP: 5.2.8
DB: 5.1.30-community
Kunena: 1.5.3
Yes, the file "kunena.communitybuilder.php" is there.
Yes if I set the kunenalatest module active with kunena settings without CB integration then it's ok! (but of course, no avatar, etc)
(If I try to put either profile or avatar integration, then I get the error message)
Time to create page: 0.378 seconds
