Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
17 years 3 months ago - 17 years 3 months ago #20124 by den07y
note: I removed Kunena 1.0.10 before installing Kunena 1.53
Last edit: 17 years 3 months ago by den07y.
17 years 3 months ago #20127 by jerry
den07y wrote:
Thanks for your message, this is my configuration and actions:
I installed the new Kunena module localy to my computer. (Before installing the module to the final web site...)
OS: Windows XP Pro
Joomla: 1.5.11
PHP: 5.2.8
DB: 5.1.30-community
Kunena: 1.5.3
Yes, the file "kunena.communitybuilder.php" is there.
Yes if I set the kunenalatest module active with kunena settings without CB integration then it's ok! (but of course, no avatar, etc)
(If I try to put either profile or avatar integration, then I get the error message)
I will do some tests tomorrow, hopefully it's only problem of Program Files. I am using xampp for myself and it works from c:\xampp...
17 years 3 months ago #20187 by jerry
OS: Windows XP Pro
Joomla: 1.5.11
PHP: 5.2.8
Kunena: 1.5.3
I will do some tests tomorrow, hopefully it's only problem of Program Files. I am using xampp for myself and it works from c:xampp...
I will resolve this issue today in version 1.0.41.
17 years 3 months ago #20195 by jerry
Replied by jerry on topic Re:Kunena latest posts module
version 1.0.41 - resolved CB issue in some environments
17 years 3 months ago #20196 by den07y
Great!!!
:woohoo:
17 years 3 months ago #20198 by den07y
I just saw that you already did the new version!
Thanks a lot!
I will test it tonight at home (I'm in France).
Cheers,
Denis
Time to create page: 0.219 seconds
