Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
17 years 5 months ago #12832 by metaltome
I'm also having problems with this module and mootools. Menu and other modules that use mootools stop working when I have this Kunena Latest Module Enabled. :(
17 years 5 months ago #12836 by metaltome
Brunus wrote:
BiO wrote:
I had an error with my GK-Tabs animation with 1.0.38 version.
Just comment lines 38 > 40 in helper.php solve the problem.
//if (defined('KUNENA_JQURL') && !isset($jQuery)) {
// $mainframe->addCustomHeadTag('<script type="text/javascript" src="' . KUNENA_JQURL . '">jQuery.noConflict();</script>');
Thx jerry for your work.
Thanks ! This trick solved my problem with a mootool based module too. Many thanks !
Nevermind this worked ;)
17 years 5 months ago - 17 years 5 months ago #13013 by dragonizer
How do I show the latest posts on the front page of my site??
I have tried mod_kunenalatest and my site will not load when I enable it.
I have not mentioned In my previous posts I am a Joomla Newbie, I am just converting an existing site to Joomla.
Last edit: 17 years 5 months ago by dragonizer.
17 years 5 months ago - 17 years 5 months ago #13015 by sozzled
:) There are two ways (that I know) you can do this:
Last edit: 17 years 5 months ago by sozzled.
17 years 5 months ago #13574 by BoonDockSaint
If someone have solved the problem with the module and mootools, why don´t you update the module??
Just that i am not a codeexpert, and will not try to change code myself :woohoo:
17 years 5 months ago #14246 by theprofessor
I have installed the latest version of KunenaLatest onto my site, and it works very well...
...BUT...
It is interfering with at least 2 modules in my website: JA-Tabs, and JA Slideshow 2.
The modules dissapear when KunenaLatest is on.
Does anyone know of a solution to this?
Any help is greatly appreciated!
Time to create page: 0.223 seconds
