Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
17 years 6 months ago #12230 by bertm
Great module. Playing around with Item Format. Very flexible. Since it is hard to see all of the options from the mouseover, I will include them here.
%S - short subject,
%L - full subject,
%M - short message,
%T - message,
%N - name,
%D - date,
%F - forum,
%H - thread hits,
%C - number of replies,
%R - unread indicator,
%A - avatar,
%O - online status
PROBLEM: I am trying to insert a few non-break-spaces into the mix. Either &nbsp or &#160. They seem to work ok, then after the module is reopened and saved, they are converted into ? question marks. Other special characters seem to work ok (are not lost after the second save).
What do you think?
17 years 6 months ago #12232 by BoonDockSaint
Hi guys
Can the devellopers pls come up with something about the mootools problem? Maybe a reply if they gonna fix the problem?? :dry:
Best regards
17 years 6 months ago #12233 by Brunus
BiO wrote:
I had an error with my GK-Tabs animation with 1.0.38 version.
Just comment lines 38 > 40 in helper.php solve the problem.
//if (defined('KUNENA_JQURL') && !isset($jQuery)) {
// $mainframe->addCustomHeadTag('<script type="text/javascript" src="' . KUNENA_JQURL . '">jQuery.noConflict();</script>');
Thx jerry for your work.
Thanks ! This trick solved my problem with a mootool based module too. Many thanks !
17 years 6 months ago #12237 by g7guitarist
Hey thanks that worked like a charm.
Cheers
L
17 years 6 months ago - 17 years 6 months ago #12631 by itgl72
I had this problem before, and was hoping it might be fixed with a recent update I did to J 1.5.10, K 1.09, and Latest posts module version 1.0.38.
The problem exists in IE7 but not in FF 3.
When I hover over the subject of a post displayed in the latest posts module I see a TOOLTIP which displays the name of the forum the post is in and the title of the post. It also shows replies which I added. BUT IT ONLY WORKS IN FIREFOX.
When I view it in IE and hover over the subject I get NO ToolTip with the information mentioned above.
Is there a fix I can do, or is this something that the dev needs to work on?
Thanks...
Last edit: 17 years 6 months ago by itgl72.
17 years 6 months ago #12781 by bytebandit01
jerry..
i'd like to add this code.. to replace in line 67 in helper.php
although this code works for showing user avatar..
$msg_avatar = KUNENA_LIVEUPLOADEDPATH . "/avatars/$avatar";
..but problem is when a user avatar is not of standard size it breaks the alignment of the display by showing the thumbnail of the avatar with a different dimension.
however this code..
$msg_avatar = (!file_exists(KUNENA_ABSUPLOADEDPATH . '/avatars/s_' . $avatar)?KUNENA_LIVEUPLOADEDPATH.'/avatars/'.$avatar:KUNENA_LIVEUPLOADEDPATH.'/avatars/s_'.$avatar);
..ensures that all displayed avatars will be of the same dimensions.
