Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
17 years 5 months ago #14538 by tamerax
it is enabled so if i turn this off, it will update at the same time the posts are actually made?
17 years 5 months ago #14560 by Matias
Yes. Page cache delays every change you make in your site max 15 minutes (depending on your settings). You do not have to turn it off (it makes your site faster), but smaller value would be great too.
There is a way to get around that cache, but I don't know if you should use it for a module..
17 years 4 months ago #16845 by Moset
Replied by Moset on topic Re:Kunena latest posts module
i get this error
Warning: require_once(/components/com_kunena/lib/kunena.communitybuilder.php) [function.require-once]: failed to open stream: No such file or directory in /home/domains/public_html/modules/mod_kunenalatest/helper.php on line 23
Fatal error: require_once() [function.require]: Failed opening required '/components/com_kunena/lib/kunena.communitybuilder.php' (include_path='.:/usr/local/php5/lib/php') in /home/domains/public_html/modules/mod_kunenalatest/helper.php on line 23
:blink:
Kunena: 1.51b
Joomla: 1.5.10
17 years 4 months ago #16873 by jerry
Replied by jerry on topic Re:Kunena latest posts module
Moset wrote:
i get this error
:blink:
Kunena: 1.51b
Joomla: 1.5.10
It looks like your installation of Kunena 1.5.1b is broken. Can you confirm, that file /components/com_kunena/lib/kunena.communitybuilder.php exist? It should exist in that place. Confirmed from svn tag 1.5.1b, tag 1.0.10, also in trunk 1.5.
Try reinstalling your Kunena.
17 years 4 months ago - 17 years 4 months ago #16879 by Moset
jerry wrote:
Moset wrote:
i get this error
:blink:
Kunena: 1.51b
Joomla: 1.5.10
Yes i have that file :( will try reinstall
Edit: reinstalled it ... didnt work cry
Edit again: installed Kunena 1.0.10 and it worked :)
I keeped my old jos_fb_categories table from kunena 1.5.1b it worked but is it stable ?
Last edit: 17 years 4 months ago by Moset.
17 years 4 months ago #16907 by jerry
I tried it on my test environment Joomla 1.5.10, CB 1.2.1, Kunena 1.5.1b, mod_kunenalatest 1.0.39 and it works nicely. No warnings, no errors, module works.
Time to create page: 0.268 seconds
