Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
17 years 3 months ago #20204 by jerry
den07y wrote:
I just saw that you already did the new version!
Thanks a lot!
I will test it tonight at home (I'm in France).
Cheers,
Denis
Hopefully it will work, if not, just send your issue.
17 years 3 months ago - 17 years 3 months ago #20333 by etusha
for html error
i think i fix that
at helper.php line 242 $s = str_replace('title=""', 0, $s); comment it
validator.w3.org/check?uri=http%3A%2F%2Fwww.lundro.al%2F
Last edit: 17 years 3 months ago by etusha.
17 years 3 months ago #20340 by den07y
Hi!
Ok it looks better but I still have a warning/error message in the main display pannel:
Notice: Constant KUNENA_CB_ITEMID_SUFFIX already defined in C:\Program Files\xampp\htdocs\ailesdesignes\components\com_kunena\lib\kunena.communitybuilder.php on line 34
Thanks in advance for your help!
cheers,
Denis
17 years 3 months ago #20348 by jerry
Replied by jerry on topic Re:Kunena latest posts module
etusha wrote:
for html error
i think i fix that
The problem with this is, that it's there for a reason. It fixes hover text in IE. Well... the question is why there is issue on the validator as I am not breaking html maybe I am breaking strict xml. Give me some time, to resolve this issue.
17 years 3 months ago - 17 years 3 months ago #20353 by ugur
Replied by ugur on topic Re:Kunena latest posts module
Hi jerry
Turkish language file was updated
Best Regards
JTR
File Attachment:
File Name: tr_TR-20090617.zip
File Size:1.19 KB
Last edit: 17 years 3 months ago by ugur.
17 years 3 months ago #20354 by kmilos
I can confirm this notice as well with 1.0.41 on K 1.5.3, J 1.5.11, CB 1.2.1
Time to create page: 0.366 seconds
