15 years 8 months ago #88965 by eycel
ok thanks for your help, I found this thread here which explains in detail my problem exatly, now to see if the solution actually works.
15 years 8 months ago #88966 by eycel
ok confirmed and tested, all I had to do in my template was to switch a setting in advanced in templates configuration, it was Build Title Spans which was on, you have to turn that off.
15 years 8 months ago #88968 by ashquadir
My Editor toolbar above the Emoticons in the Boardcode in the New Topic form does not appear.
Is there a away to have this show up?
Also, there a way to create hove text for each Topic Icon?
What do each of these icons mean (e.g. the right arrow, what does it mean?)
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : PlanetHop_Template_1 | author: Ash Quadir | version: 1.0 | creationdate: 2011-02-28
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Installed (Version : 2.0.5) | UddeIm: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Enabled (Version : 1.6.0-RC1)
15 years 8 months ago - 15 years 8 months ago #88969 by sozzled
ashquadir wrote: What do each of these icons mean (e.g. the right arrow, what does it mean?)
These icons can mean whatever you would like them to mean.
ashquadir wrote: Is there a way to create hove text for each Topic Icon?
Yes, it's possible to do this but the feature has not yet been included with K 1.6. If you would like this feature to be added to a future version of Kunena, please start a new topic in the Feature Requests category.
ashquadir wrote: My Editor toolbar above the Emoticons in the Boardcode in the New Topic form does not appear. Is there a away to have this show up?
Please see msg #1 in this topic.
15 years 8 months ago #89095 by dcasmr
Hello
My boardcode does not show and I have contacted the template designer as well jomsocial. I have tried to disable many js, however, I have the attached mootools error I don't understand.
Can anyone help me?
I have been trying to solve this for a month now...
15 years 8 months ago #89096 by sozzled
Please see msg #1 in this topic. If, however, you are unable to resolve this issue yourself, we may be able to help (on a fee-for-service basis) if that is agreeable to you.
Time to create page: 0.181 seconds
