15 years 2 months ago - 15 years 2 months ago #103972 by heroksiddiqi
Replied by heroksiddiqi on topic bbCode is not working
I am using kunena 1.6.4.
I cannot use bbCode option.
In the box where bbcode list should be shown is empty.
I am Using alledia Bolt template.I think the javascript of this template conflict with kunena.If i use another template,it works.
Is there any way to get the bbcode option without changing template?
Last edit: 15 years 2 months ago by heroksiddiqi.
15 years 2 months ago #103977 by sozzled
heroksiddiqi: Please see msg #1 in this topic.
15 years 2 months ago #104405 by mchan004
Do not show ?
15 years 2 months ago #104409 by sozzled
15 years 2 months ago - 15 years 2 months ago #104413 by mchan004
mannumobile wrote: BBCode formatting bar is missing.
Kunena : 1.6.3
Joomla : 1.5
Template : RT_Magz
Sory I dont know
I have reinstalled but still
How to fix this ??????
Last edit: 15 years 2 months ago by mchan004.
15 years 2 months ago - 15 years 2 months ago #104437 by sozzled
The problem has nothing to do with Kunena. The problem is caused by other software that you have installed on your website. The links contained in message #1 in this topic explain that. No matter how many times you install the same version of Kunena you will not fix your problem ... because your problem is not caused by Kunena. If you read the links contained in message #1 you will see why this is the case.
If you are using a Rockettheme template, set Build Title Spans off. If you are using K 1.6.3, upgrade to K 1.6.5. If you are using J! 1.5, make sure you're using the latest version, i.e. J! 1.5.23.
Last edit: 15 years 2 months ago by sozzled.
Time to create page: 0.162 seconds
