15 years 2 months ago #105169 by Matias
Did you try to enable debug more? That will usually tell what's wrong.
15 years 2 months ago #105177 by sozzled
>>> Here <<< is the link to the information you need.
15 years 2 months ago - 15 years 2 months ago #105271 by beernerd
On my site, warlizardgaming.com, many of the buttons are not working.
The collapse buttons will not work. Neither will the Post/Thank You/Subscription/Favorites buttons in the user profile. I tried switching back to the default template, but it did not help.
I am using Kunena 1.6.5 with Joomla 1.7.0
Joomla default template details : siteground-j16-22 | author: SiteGround | version: 1.0.0 | creationdate: 17 May 2011
Kunena default template details : Aphotic | author: snilloconator | version: 1.6.0 | creationdate: 2010-23-09
Modules: Kunena Latest 1.6.4 | Kunena Login 1.6.4
Last edit: 15 years 2 months ago by beernerd. Reason: Added configuration report
15 years 2 months ago #105279 by xillibit
15 years 2 months ago #105288 by beernerd
Thank you, that's much more straightforward than anything I was able to find on my own.
Apparently the issue is caused by a lack of Mootools. Unfortunately, I can't find a Mootools plugin that is compatible with Joomla 1.7. Has anyone successfully installed Kunena with Joomla 1.7?
15 years 2 months ago - 15 years 2 months ago #105290 by 810
Joomla 1.7 have already mootools 1.2
So it must be working.
Please try default kunena. and joomla template
Last edit: 15 years 2 months ago by 810.
Time to create page: 0.182 seconds
