15 years 3 months ago #104640 by hotbullet
Replied by hotbullet on topic editor no show icons
hi my editor is not showing the icons.. it is like this now.
i have two sites both are like this. .what can i do please help.
[IMG
thanks.
web is test.logic.co.th
15 years 3 months ago #104679 by sozzled
G'day, hotbullet, and welcome to Kunena.
Please see msg #1 in this topic.
15 years 3 months ago #104698 by hotbullet
sozzled wrote: G'day, hotbullet, and welcome to Kunena.
thanks.. i have tried reading but could not find the topic. can you please help.
thanks.
15 years 3 months ago #104699 by sozzled
>>> Here <<< is the link to the information you need.
15 years 3 months ago #104700 by hotbullet
sozzled wrote: >>> Here <<< is the link to the information you need.
thanks for your quick help.. i have followed your link.. and it worked perfect. i will make sure to help everyone who comes across this too..
you made my day.
Incompatible Mootools version loaded
The only cause is that Mootools 1.1 is loaded instead of Mootools 1.2.
Plugin Manager 1. Using the Joomla Plugin Manager, ensure that System - Mootools Upgrade plugin is the first system plugin to be loaded
2. If this does not solve the problem, enable the System - Mootools Upgrade plugin[4]
In the event that these measures do not work the cause is most likely that you are using software that is old, outdated and probably no longer supported. If you view the HTML source of your Kunena pages you will see a list of all Javascript loaded (these are filenames with the extension .js). By looking at the file path you can probably find which extension is responsible for loading these Javascript libraries. In the first instance, we recommend you seek the assistance of the developer of the extension that you think is responsible for the conflict, particularly if you purchased the product.
15 years 3 months ago #105058 by Klamort
Replied by Klamort on topic BBcode are gone
I am using J1.7 and the latest Kunena 1.65, cb1.7 and for some reason my BBcode are gone....
Did anyone already had this problem too... and how to fix it...
thanks for your help.
Time to create page: 0.156 seconds
