15 years 3 months ago #102869 by lightbots
I've disabled the buildspans in Gantry and it works, I've tried to do the other steps but the only files I have in com_gantry are controller.php and ganrty.php and no directory.
Thanks so much none the less!!!
15 years 3 months ago #102871 by hannylicious
lightbots wrote: I've disabled the buildspans in Gantry and it works, I've tried to do the other steps but the only files I have in com_gantry are controller.php and ganrty.php and no directory.
No problem.
Strange you don't see all the things in your com_gantry folder.. I wonder where they're at?
Anyway - glad the fix got you all sorted out! It flustered me for a few days before I realized what was going on!
15 years 3 months ago - 15 years 3 months ago #102876 by lightbots
hannylicious wrote: No problem.
Yeah I wondered that as well, maybe the update moved some files? Not sure
Last edit: 15 years 3 months ago by lightbots.
15 years 3 months ago #102882 by hannylicious
Usually an update just changes the files it needs to update and leaves everything else in place. Really strange that happened.
Are you using a rockettheme template, or just Gantry itself with a custom template?
15 years 3 months ago #102893 by sozzled
G'day, lightbots, and welcome to Kunena.
See msg #1 in this topic.
Thanks, hannylicious, for your help on this matter. Yes, it's almost certainly a Javascript library conflict problem.
15 years 3 months ago #102897 by lightbots
hannylicious wrote: Are you using a rockettheme template, or just Gantry itself with a custom template?
Yup a rockettheme with Gantry called cloudbase2.0
Time to create page: 0.159 seconds
