15 years 3 months ago #102198 by cellardoor_ncx
Sozzled - thank you for help, but I've already got through "common causes of mootools and kunena" and found no help. So, what do you mean by using "one or two menu options" ? I'm pretty dependant on mootools 1.12 as my project is almost over. What are my options ? Maybe I should go with Kunena 1.5.9 or some pre 1.6 release instead ?
15 years 3 months ago - 15 years 3 months ago #102199 by sozzled
If you are dependent on an outdated version of Mootools, I can only recommend an outdated (and soon to be unsupported) version of Kunena, or some other forum software that doesn't rely on Javascript software. These days even the current web browsers (IE 9, Firefox 4, Google Chrome, for example) need the recent Mootools library to properly handle Joomla websites. Sorry. K 1.5.14, perhaps? (I wouldn't recommend it)
Most other forum software for Joomla uses these recently updated Mootools libraries, too. You will probably have to go outside Joomla for a "bridged forum" solution if Mootools 1.1 where you need to stay.
90% of the problems that people have with K 1.6.x are mostly caused by using old, unsupported Joomla site templates.
Last edit: 15 years 3 months ago by sozzled.
15 years 3 months ago #102204 by cellardoor_ncx
I see. You know, the problem is I started to build this website on Joomla 1.5.23 and Ja Purity II because of several reasons, I didn't know the client would like to have a forum solution back then. So I think it is a matter of getting Ja Purity II to work with mootools 1.2 rather than working around problems in Kunena. Out of curiosity, what option would you choose ?
15 years 3 months ago - 15 years 3 months ago #102263 by sozzled
I think you nailed the issue with your client's recent epiphany (or, as we might say Which came first? The template or the forum? )
I would not waste my time with JA Purity II; I mean, I spent about 45 minutes with it one day, got it to work with K 1.6, said to myself "big deal" and then I disposed of it. People an over-agonise about the choice of site template; at the end of the day you have to ask yourself what's more important to you: functionality or eye-candy? Good ol' JA_Purity that comes free, out-of-the-box with J! 1.5.23 works just as well and, to the untrained eye, isn't that much different to JA Purity II. The original JA_Purity is still the best ... and it works with Mootools 1.2.5. It's a two-minute fix-it.
15 years 3 months ago - 15 years 3 months ago #102438 by kunSNOW
Replied by kunSNOW on topic Edit Profile not working
Hi
I have just set up a Joomla site (1.5)
I have installed a RocketTheme template, if that helps diagnose the issue.
I installed Kunena today, version 1.6.5.
I have the default template installed.
I have found that if I go to Profile and click the edit button, the panel appears, but there is no information and none of the tabs work.
I have enclosed a screenshot to show the situation.
Can anyone give any solutions?
*** Found that there is a plug-in called "System - Mootools Upgrade" if it is turned on the info and tabs work, but the Edit button disappears. If it's switched off then the edit button works but no information is there. The version is: Mootools 1.2.5 ***
Thanks in advance
Last edit: 15 years 3 months ago by kunSNOW. Reason: Found extra info!
15 years 3 months ago #102520 by sozzled
G'day, kunSNOW, and welcome to Kunena.
Please see msg #1 in this topic.
