Question Links don't work
16 years 4 months ago #54117 by Hurr1c4n3
Replied by Hurr1c4n3 on topic Re: Links don't work
Yes, htaccess is renamed.
Everything works with the the 1.5 version of Kunena. ( www.natuurfocus.com/site/forum.html )
The testsite is a exact copy of the live site. Copy made with Akeeba Backup.
16 years 4 months ago #54122 by @quila
Replied by @quila on topic Re: Links don't work
Hmmm...
if I understand, you have make acopy of site with K1.5, then you are upgrade K1.5 -> K1.6, enabled SEO and links dont work. Right?
Both site are on the same server?
Try also to change Joomla template and say what heppens. Thank you.
16 years 4 months ago - 16 years 4 months ago #54140 by Hurr1c4n3
(Back from work)
No, both sites use SEO. The only thing I did was make a copy of the original site and then upgrade kunena to the 1.6 beta 1.
I also changed the theme now to the default JA_Purity theme and the same problem persists.
The 2 website are run on the same server.
On the side:
I also installed a clean Kunena 1.6 beta 1 on another server of the same hosting provider and there works everything.
Last edit: 16 years 4 months ago by Hurr1c4n3.
16 years 4 months ago #54146 by @quila
I would at your place create new copy of original site and go step by step to find in which point all operation is broken. I mean install K1.5 and enable SEO, look if all works well, then update to K1.6 and see if there are some error, If not enable SEO.
16 years 4 months ago #54149 by Hurr1c4n3
The original site has kunena 1.5 installed so I don't have to install that again. SEO also is activated in the original site.
The only thing I did was, copied the original site with Akeeba to the new domain and then installing 1.6 beta 1 over the 1.5 installation.
16 years 4 months ago #54159 by sozzled
Replied by sozzled on topic Re: Links don't work
Hurr1c4n3 wrote: All options set to Yes
I think that's the problem. I've never been able to get everything on my Joomla websites to work properly if I use that third option: Add suffix to URLs = Yes.
See my guide in the Wiki and try those suggestions: Search engine optimization (SEO)
