Question Links don't work
16 years 4 months ago #54298 by Hurr1c4n3
Replied by Hurr1c4n3 on topic Re: Links don't work
When I click that menuitem I can choose the following:
I then changed it to entrypage. After that I can change:
I doesn't matter what i choose. I always will be redirected to the index page.
16 years 4 months ago - 16 years 4 months ago #54320 by sozzled
Replied by sozzled on topic Re: Links don't work
Ah ... I think I had this issue last night (when I upgraded, downgraded, uninistalled, installed and re-installed Kunena). It's a bit clumsy at the moment, but this is how I went about solving my problem (how to select the whole Kunena menu, not just one tab from it).
  1. Use Menu Manager to "trash" all of your Kunena menu items (and trash any existing menu links to your forum, too)
  2. Empty the trash - permanently delete all menu items
  3. Go to the Kunena control panel and click the Create Menu. This should re-create your Kunena menus and create a link for your forum in your default menu.
I know, this is exactly what @quila wrote earlier but I found that perseverance and patience will eventually triumph. In my opinion, this aspect of the Kunena installation procedure is, perhaps, the single biggest stumbling block to bring about K 1.6 as a stable release.
Last edit: 16 years 4 months ago by sozzled.
16 years 4 months ago - 16 years 4 months ago #54323 by Hurr1c4n3
Thank you for your reply Sozzled. I allready did that a few posts back
www.kunena.com/forum/156-kunena-16-test-...it=10&start=20#54268
Did partly solve the first problem.
Edit: Ok I'll try it again.
Last edit: 16 years 4 months ago by Hurr1c4n3.
16 years 4 months ago - 16 years 4 months ago #54324 by sozzled
Let me see if I understand this correctly:
  • I visited your website
  • You have a link to your Forum
  • The first page that you're taken to is the Index page
  • The links on the Index, Recent Topics, etc., tabs take you where they're supposed to take you
  • The links on categories or threads also take you where they're supposed to take you
  • In other words, everything is working as it's supposed to be working, right? I mean, what part of what I saw was only a partial solution?
I think there's a new problem here: you can't create another link just like the one that was created for you by the Kunena Create Menu facility. Does that summarise your current situation?
16 years 4 months ago #54325 by Hurr1c4n3
I don't believe it!:pinch: Now it works?:blink: :woohoo:
I'll try it all again tomorrow. I'll make a new copy and that upgrade kunena again. Got to go to bed now. Have to work very early tomorrow morning.
16 years 4 months ago #54326 by sozzled
Yes, I told you ... I spent a couple of hours on this very same thing last night. Trashing, deleting, pressing every button I could possibly think of and, just like you, quite unexpectedly, everything suddenly worked. Do you now understand why you need perseverance and patience (and a few grains of good luck) to handle some issues in K 1.6?
