Question Links don't work
16 years 4 months ago #54093 by Hurr1c4n3
Links don't work was created by Hurr1c4n3
After I installed the new beta on a testsite everything looks OK, but what I link I click none of them work.
Try it yourself:
www.natuurtest.nl/site
login : test
pass : kunena
You can make a new topic, you can't open an old or new topic. You can't go the a specifiek categorie. In all cases you will be forwarded to the recent topics list.
16 years 4 months ago #54095 by @quila
Replied by @quila on topic Re: Links don't work
Hi, what is SEF/SEO component you are using?
How is configured that component?
Have you try to clean cashe (first disabling SEF/SEO)?
16 years 4 months ago #54102 by Hurr1c4n3
Replied by Hurr1c4n3 on topic Re: Links don't work
I don't have a SEF/SEO component running. Just the one of Joomla itself.
I have already tried to clear the cache but that doesn't help. Tried it again but the same problem persists.
16 years 4 months ago - 16 years 4 months ago #54103 by @quila
Ok, and how is configured joomla SEO, what option is checked?
And if you disable SEO does form works normally?
Last edit: 16 years 4 months ago by @quila.
16 years 4 months ago - 16 years 4 months ago #54104 by Hurr1c4n3
All options set to Yes.
When I disable SEO everything works OK.
When I enable SEO and the disable the other options it doesn't work anymore.
Last edit: 16 years 4 months ago by Hurr1c4n3.
16 years 4 months ago #54109 by @quila
Good, now, have you renemed htaccess.txt to .htaccess in joomla root?
If not you cant check second option.
First option is OK.
Third option activate only when you see all works well with first two.
