Sticky migrating Joomla 1.x+Smf 1.x to Joomla 1.5+kunena Script
16 years 1 month ago #56004 by Dannymh
Sorry about the delays guys.
We are in our busy period at work (I work for an education software company) so we are getting hammered. I have had no time to work on this.
The release I have here has a massive flaw in it, I have a fixed release but need to re-check it and re-run it.
I also need to convert all html to bbcode but not sure I will have the time to do this
15 years 8 months ago #82266 by jdimaging
I was all set to do this, put everything where you said to put it but I need to ask this question:
Where do I put smf3k.php -> replace old
I put it in the root and tried to run it but just got a bunch of sql errors.
Once I confirm this I will try it again.
I tried to look for a file with this name in my smf forum but didn't find it.
Really would like to do this as am all set to change to Kunena.
Thanks in advance.
Darlene
15 years 7 months ago #84442 by Doc
I used the smf2k script and once I got the quotes issue fixed it connected and made it to Step 2...and got this:
Done in 0You're on step 2
Populating Messages Table...
Populating Ok!!!
Populating MessageText Table...
Populating Ok!!!
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'll' and ordering=16' at line 1
I'm not exactly sure what this means, but I can smell that I'm getting close! The forums seem to be imported into Kunena, but no messages or users. It's at least connecting to the right DB and grabbing some info before it croaks.
Any ideas? Thanks in advance for any help.
15 years 7 months ago #84443 by Doc
PS: I would welcome any recommendations for a developer to help me migrate a non-profit musicians' site from SMF 1.1.2 standalone to J1 1.5/Kunena 1.6.
Thanks!
15 years 7 months ago #84508 by ken79
I chose kunena for the reason that there was no appropriate solution for the smf forum in joomla. That’s why i went for kunena and changed some script. I will try this script because it seems to work just fine with you own upgrades. I will probably play with it and invent some more so i can come up with the set up i prefer.
15 years 7 months ago #84509 by ken79
@doc
I am not sure just yet but i am sure you are connecting to the database. There seems to be a problem with the syntax you used and its compatibility to the version of MySQL you used. I do not know also but that’s what i think it is. Are you sure you were able to plugin the smf2k script properly?
Time to create page: 0.224 seconds
