- Thank you received: 1
Sticky migrating Joomla 1.x+Smf 1.x to Joomla 1.5+kunena Script
16 years 3 months ago - 16 years 3 months ago #49988
by Dannymh
Replied by Dannymh on topic Re: migrating Joomla 1.x+Smf 1.x to Joomla 1.5+kunena Script
Ok
The following changes have been made ( i still need to write you a new authentication plugin)
Anyway, use the first script "smf2k.php"
WARNING: This new script deletes all existing Joomla users
one more time
THIS SCRIPT DELETES ALL EXISTING JOOMLA USERS SO BACKUP THE JOS_USER TABLE FIRST
anyway run this script, then upload teh script called "tools.php
to you Joomla root directory, run this and enter your Username and Password
You will then be put back in as a Super Administrator and you will have your password working.
At this point you will be able to login, but your users will not as their passwords will be salted with the SMF SALT
Tomorrow I will write you a script that will update your users passwords on their first correct login and MD5 hash them.
This is very ugly scripting but it works
The tools.php is thanks to the jfusion team. I altered it to change the password also so thanks to that team for a quick and good script to do this
Just for parity
THIS DELETES ALL JOOMLA USERS SO TAKE A BACKUP FIRST
removed download file as I just realised that the original author was re-hashing the already hashed passwords, making for a double hash and overheads for login. The new download includes an authentication file and the fixed "as-is" password
one more time
Just for parity
Last edit: 16 years 3 months ago by Dannymh.
16 years 3 months ago #49993
by Dannymh
Ok new version of the script
Full convert, fresh Joomla, old SMF. This will delete all Joomla users.
You have been warned!
This script puts the passwords into the database straight into the database from SMF.
There is a Joomla.php that you place in your plugins/authentication folder, (backup your old and replace with this one)
What this does is it checks to see if the login works with standard Joomla authentication, if this fails, it checks it against the SMF crypt (basically SMF uses SHA1 + salt and Joomla uses MD5 + salt> I removed the salt for now though but joomla will fix that.
Anyway if the password then match the SMF hash it updates your record to the standard Joomla hash and logs you in.
The reason i did this is that over time, say 3 - 6 months the majority of your users would have logged into Joomla and therefore update their passwords, after that time you can revert to the latest Joomla.php authentication file and login as normal, the users who had not yet logged in can simply retrieve their passwords via joomla password retrieval.
Simple huh?
Any questions let me know
- tools.php -> joomla root (thanks jfusion.org team)
- joomla.php -> plugins/authentication/
- smf3k.php -> replace old
enjoy
- One more warning can't hurt. THIS WILL DELETE ALL EXISTING JOOMLA USERS
Dan
* next I might work on a phpBB converter and eventually clean this up so it actually looks kind of nice and the code isn't so hacky and messy
Simple huh?
enjoy
Dan
16 years 3 months ago #49994
by tamirzzz
Replied by tamirzzz on topic Re: migrating Joomla 1.x+Smf 1.x to Joomla 1.5+kunena Script
This is Tamir who started the intial post
I could not have imagined that my post would sitmulate reactions from so many people. I guess, This is the beuty of open source.
Because there was not really a good way of migrating smf to anything in Joomla 1.5x, It postponed my upgrade to Joomla 1.5 for almost a year.
Now I am glad that if someone runs into the same problems I had a while ago, she\he could easly solve these.
On behalf of the Joomla 1.x+Smf 1.x users :woohoo: Thank you all for your contribution.
Tamir
Tamir
- kraymitchell
- Junior Member
16 years 3 months ago #50018
by kraymitchell
Replied by kraymitchell on topic Re: migrating Joomla 1.x+Smf 1.x to Joomla 1.5+kunena Script
Thanks Danny!
I will give this a try and let you know how it goes.
So... will this delete my current Joomla users?
:laugh:
- kraymitchell
- Junior Member
16 years 3 months ago - 16 years 3 months ago #50021
by kraymitchell
OK, so there was a DB error and I lost my post
Here goes again..
OK, the script seemed to run OK, but there were a few issues (So far, all I have found).
1. This error came up at the end of the script:
2. When you view categories, everything in the 'Last Post' column shows as updated today at xx:xxpm (The time changes to the current time every time you click the Categories Tab). If you go into the actual category, it shows the correct date.
I am not sure if this would be fixed if I ran the Recount Board Totals (Read next issue)
3. While I am able to login to the front end, I cannot login to the admin side. I took a look at the DB (in jos_users)and the admin user was set to Registered. I set it to Super Administrator, but that didn't do anything. I compared the Field and Type columns to another Joomla installation and found some differences. I have copied them below:
Here goes again..
Enjoy kunena!
connecting Kunena to Joomla...
Invalid query:
CANNOT POST OR PM, SEE ATTACHMENT
[b]OTHER JOOMLA INSTALL
FIELD TYPE[/b]
id int(11)
name varchar(255)
username varchar(150)
email varchar(100)
password varchar(100)
usertype varchar(25)
block tinyint(4) 0
sendEmail tinyint(4) 1
gid tinyint(3) unsigned 25
registerDate datetime
lastvisitDate datetime
activation varchar(100)
params text
[b]KUNENA JOOMLA INSTALL
FIELD TYPE[/b]
id int(11)
name text
email varchar(100)
usertype varchar(75)
block tinyint(4) 0
gid tinyint(3) unsigned 0
params text
Last edit: 16 years 3 months ago by kraymitchell.
16 years 3 months ago - 16 years 3 months ago #50041
by Dannymh
To fix the dates, just recount the totals, the script wont effect these.
As for the admin. did you run tools.php and set to Super Administrator??
Time to create page: 0.171 seconds
