Solved Forum Permissions
11 years 3 months ago #166278 by applehc
Replied by applehc on topic Forum Permissions
810 wrote: backend - kunena - tools - sync users
Thank you.
I have only check Add user profiles to everyone
Kunena adds new user profiles only if user enters to the forum. This function makes default profiles to all existing users.
Uncheck:
Remove user profiles from deleted users
Update user names in messages
Delete lifetime ban users
11 years 3 months ago #166296 by rich
Replied by rich on topic Forum Permissions
applehc wrote: I installed Joomla 2.5.8 with Kunena Kunena 3.0.6. Then I replaced joomla users and kunena tables but permissions error continues :(
Perhaps a idea.
1. Create a complete backup from the old page
2. Update to Joomla 2.5.28 (not to 2.5.8)
3. Deinstall all extensions except Kunena
4. Upgrade Kunena
5. Check if all works
6. Upgrade to Joomla 3.4
7. Check again
8. Export User and Kunena tables
9. Import the tables in the new Page
10. Install Kunena 4.0
11 years 3 months ago #166297 by 810
Replied by 810 on topic Forum Permissions
fixed, the issue. by updating joomla and kunena.
11 years 3 months ago #166298 by applehc
810 wrote: fixed, the issue. by updating joomla and kunena.
All good, thank you 810, you are the best!
Greets
Time to create page: 0.247 seconds
