Solved Forum Permissions
10 years 10 months ago - 10 years 10 months ago #166137 by applehc
Forum Permissions was created by applehc
When copying tables joomla and kunena in the database to use 4.0, generate changes in permits?
Users are part of "registered users" and categories are configured for it. When accessing a topic, I receive the next message:
Access Denied
EDIT:
I went to Kunena category mánager to change the categories permissions and when I saved changes for testing I receive this error:
Error
Unknown column 'icon' in 'field list' SQL=UPDATE `ubj25_kunena_categories` SET `parent_id`='7',`name`='Presentate',`alias`='6-Presentate',`icon`='',`icon_id`='0',`locked`='0',`accesstype`='joomla.group',`access`='1',`pub_access`='2',`pub_recurse`='1',`admin_access`='2',`admin_recurse`='1',`ordering`='1',`published`='1',`channels`='THIS',`checked_out`='127',`checked_out_time`='2015-06-21 12:10:50',`review`='0',`allow_anonymous`='0',`post_anonymous`='0',`hits`='0',`description`='¿Eres nuevo usuario? Presentate aquí.',`headerdesc`='',`class_sfx`='',`allow_polls`='0',`topic_ordering`='lastpost',`iconset`='default',`numTopics`='42',`numPosts`='236',`last_topic_id`='8814',`last_post_id`='11392',`last_post_time`='1377859630',`params`='{\"access_post\":[\"1\",\"6\"],\"access_reply\":[\"1\",\"6\"],\"display\":{\"index\":{\"parent\":\"3\",\"children\":\"3\"}}}' WHERE `id`='6'
Last edit: 10 years 10 months ago by applehc.
10 years 10 months ago #166139 by 810
Replied by 810 on topic Forum Permissions
Go to the database and open *_kunena_version Remove all 4.0 entries. Then install kunena 4.0.1 again by the joomla installer.
The following user(s) said Thank You: applehc
10 years 10 months ago #166145 by applehc
Replied by applehc on topic Forum Permissions
I open *_kunena_version database and I delete the tables. Then I install kunena 4.0.1 by the joomla installer and created me the table.
Permissions problem on the issues continued.
10 years 10 months ago #166150 by 810
you said you did a migrate before, I don't see any other versions?
Is this a new install? Or didn't you copy all the kunena tables?
10 years 10 months ago - 10 years 10 months ago #166151 by applehc
810 wrote: you said you did a migrate before, I don't see any other versions?
It has not been an automatic migration.
I installed Joomla 3.4.1 with Kunena 4.1
Then I copy the joomla users tables and kunena all tables of the old database.
10 years 10 months ago #166152 by 810
That's wrong.
First move the data then install k4.1.
so uninstall kunena, remove the kunena tables.
Then copy the all kunena table from the old database. Then install K4.0.1
Time to create page: 0.244 seconds
