Solved Forum Permissions
11 years 3 months ago #166186 by applehc
Replied by applehc on topic Forum Permissions
Okay, I'll try.
11 years 3 months ago - 11 years 3 months ago #166196 by applehc
810 wrote: or J2.5.28
Ahhhhhhhhhh
I installed Joomla 2.5.8 with Kunena Kunena 3.0.6. Then I replaced joomla users and kunena tables but permissions error continues :(
Last edit: 11 years 3 months ago by applehc.
11 years 3 months ago - 11 years 3 months ago #166197 by rich
Replied by rich on topic Forum Permissions
If you import the Joomla 2.5 user tables to Joomla 3.4 it needs a fix. Go to "Extensions > Extension Manager > Database" and fix it. Maybe it helps.
Last edit: 11 years 3 months ago by rich.
11 years 3 months ago #166198 by applehc
rich wrote: If you import the Joomla 2.5 user tables to Joomla 3.4 it needs a fix. Go to "Extensions > Extension Manager > Database" and fix it. Maybe it helps.
Appears this:
11 years 3 months ago #166199 by rich
Appears this:
That's ok.
applehc wrote:
810 wrote: That's wrong.
First move the data then install k4.1.
so uninstall kunena, remove the kunena tables.
Then copy the all kunena table from the old database. Then install K4.0.1
Done. I copied all kunena tables of the old database and then I installed Kunena 4.1
And now? I see the default forum, all empty. I need to replace tables?
That irritates me somewhat. What do you mean with default forum? You see a clean new forum?
11 years 3 months ago #166201 by applehc
rich wrote: That irritates me somewhat. What do you mean with default forum? You see a clean new forum?
Yes, I mean the forum clean. It looks same when recently installed.
When I install Kunena 4.1 version, eats the old kunena 3.4 tables and the forum looks clean without categories, topics...
It is a headache can´t migrate the forum correctly. I'm starting a worry .
Time to create page: 0.260 seconds
