Solved Forum Permissions
11 years 3 months ago #166205 by rich
Replied by rich on topic Forum Permissions
1. Remove followings user tables in Joomla 3.4
*_usergroups
*_users
*_user_profiles
*_user_usergroup_map
2. Remove all Kunena tables in Joomla 3.4
3. Import the Joomla 2.5 user tables to Joomla 3.4
*_usergroups
*_users
*_user_profiles
4. Import the old Kunena tables to Joomla 3.4
5. Rename the prefixes (user and Kunena tables) to the same prefix as in Joomla 3.4
6. Go to Extensions > Extension Manager and fix the database
7. Install Kunena 4.0
that's all
11 years 3 months ago - 11 years 3 months ago #166209 by applehc
Replied by applehc on topic Forum Permissions
rich wrote: 1. Remove followings user tables in Joomla 3.4
*_usergroups
*_users
*_user_profiles
*_usergroups
*_users
*_user_profiles
that's all
Hello rich,
I try it, but when I finish the process I access to the web links and appears:
No input file specified.
In the second step I have not delete kunena tables because do not exist. Only exist Joomla tables of the new install.
PD: Solved with .htcaccess i go to try again...
Last edit: 11 years 3 months ago by applehc.
11 years 3 months ago #166213 by applehc
I cant solved...
Access Denied
You do not have permissions to access this page.
11 years 3 months ago - 11 years 3 months ago #166252 by applehc
I think I know the reason for the problem.
In version 2.5 I used the JX Control component for generate permits in the categories. Now, how can we solved the situation?
11 years 3 months ago #166261 by 810
Replied by 810 on topic Forum Permissions
then you need to change each category, with you wanted permissions, and save them
11 years 3 months ago #166262 by applehc
But in the new website I have nothing related to JX Control.
Really I'm a little lost.
Time to create page: 0.285 seconds
