Sticky K 3.0 Kunena menu issues
12 years 7 months ago #155404 by guidofto
Replied by guidofto on topic Kunena menu "disappears"
im sorry :) here it is
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 1024M | Max file upload: 128M
Joomla default template details : gk_shop_and_buy | author: GavickPro | version: 3.9.2 | creationdate: Unknown
Third-party components: Jomsocial 3.0_RC2
Plugins: JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1
12 years 7 months ago #155409 by 9themestore
@Sozzled,
I edited on user's site and it solved. Not bug of the Kunena component.
Regards
The following user(s) said Thank You: guidofto
12 years 5 months ago - 12 years 5 months ago #156818 by jaymzyates
I've read the wiki about creating broken menu items and utilized the trash and burn technique and yet I still can not get the menu tabs to show up in my site. I think I've checked diligently everywhere I can to troubleshoot. Any thoughts? Could it have anything to do with my home page menu item being a hidden menuset?
www.txoedev.com
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 64M
Joomla default template details : rt_hexeris | author: RocketTheme, LLC | version: 1.2 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Plugins: Content - Kunena Discuss 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Last edit: 12 years 5 months ago by jaymzyates.
12 years 5 months ago - 12 years 5 months ago #156838 by jaymzyates
I think I may be making headway. After trash and burning everything again I noticed it creates the default alias in my home menu which is hidden. I tried to move it to my main menu, but still no luck. Will the alias only work with the home menu?
12 years 5 months ago - 12 years 5 months ago #156846 by sozzled
Replied by sozzled on topic Kunena menu items missing
*** Topics merged ***
A few points in reply:
1) You are using K 3.0.4. For your information, we do not generally respond to questions/problems/issues relating to unsupported versions of Kunena. K 3.0.4 is unsupported. Our standard response in situations like yours is "Please upgrade to the current version of Kunena."
2) You are using the plugins JomSocial - My Kunena Forum Menu 2.0.3, JomSocial - My Kunena Forum Posts 2.0.3, JomSocial - Kunena Groups 2.0.3. These plugins do not work with K 3.0. Please uninstall them.
3) According to your configuration report, you have an outdated menu item (id=460). You need to delete this.
When you wrote that you have used the "trash and burn" technique, you did not look at your hidden-items menu. "Trash and burn" means just that. Trash your existing menu items and empty the trash.
Last edit: 12 years 5 months ago by sozzled.
12 years 5 months ago #156848 by jaymzyates
Replied by jaymzyates on topic K 3.0 Kunena menu issues
Thanks. I didn't realize there was a new version. I should check the site for upgrade instead of Joomla.
I performed all that was requested with no change.
I see that the config shows I have jomsocial plugins installed, but I do not. Not sure where it is reading this from. See screenshot.
screencast.com/t/ekuV8Pyqu
Time to create page: 0.189 seconds
