Sticky K 3.0 Kunena menu issues
13 years 6 months ago #144269 by mimimike64
Hello, I'm using joomla 2.5.11 and after an automatic update of kunena to version 3.0, my forum is no longer accessible and I get the following message. Thank you for the solution
13 years 6 months ago - 13 years 6 months ago #144270 by sozzled
Replied by sozzled on topic K 3.0 Kunena menu issues
I suggest you read Kunena Menu issues in the Wiki. The principles that applied in K 2.0 apply here, too.
See also How To Ask Questions The Smart Way for a faster response.
Last edit: 13 years 6 months ago by sozzled.
The following user(s) said Thank You: kapil
13 years 6 months ago #144321 by mimimike64
Replied by mimimike64 on topic K 3.0 Kunena menu issues
..ci dessous le rapport de configuration. Merci
below .. the configuration report. thank you
htaccess: Missing | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : rt_lumiere | author: RocketTheme, LLC | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.0 | creationdate: 2013-05-15
Plugins: None
The following user(s) said Thank You: leito
13 years 6 months ago #144339 by sozzled
It may be a good idea if you set your Kunena integration plugin settings in the way they are shown in Forum integration with other Joomla extensions .
It is also worth reading Search Engine Optimisation (SEO) in the Wiki.
The following user(s) said Thank You: azari59m
13 years 6 months ago #144364 by mimimike64
Bonjour et merci mais j'ai tout essayé et rien ne fonctionne. Je vais reconstruire mon site afin de pouvoir installer le version 2.0.
Hello and thank you but I have tried everything and nothing works. I will rebuild my site in order to install version 2.0.
13 years 6 months ago #144370 by Graça
Replied by Graça on topic K 3.0 Kunena menu issues
Hi
After update to 3.0 version, appears error 500 page not found. What is wrong?
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : shape5_vertex | author: Shape5.com | version: 2.0 | creationdate: Unknown
Kunena default template details : Orao - Kunena 2.x | author: www.TemplateKunena.com | version: 1.0.3 | creationdate: 15.12.2012
Plugins: Search - Kunena Search 3.0.0
Time to create page: 0.178 seconds
