Sticky K 3.0 Kunena menu issues
13 years 3 months ago #147478 by BryanG
I just installed Kunena on the latest version of Joomla. However, I the Kunena menu at the top of the forum pages keeps disappearing. I've restored the menu several times using the Restore Menu option under the Menu Manager, but then it just ends up going away again.
Here's my configuration:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 200M
Joomla default template details : iReview2 | author: ClickFWD LLC | version: 2.1.1 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Plugins: None
13 years 3 months ago - 13 years 3 months ago #147484 by sozzled
G'day, Bryan, and welcome to the forum.
You have two conflicting items in your mainmenu menu. Delete menu item id=127 (the one called "forums") and you should be OK.
I looked at your site. It certainly is difficult to navigate to where Kunena is without logging in, isn't it? And, without a user account on your site, I can't even get past the first page.
*** Topics merged ***
I suggest you use look at the Wiki article called Kunena menu issues, you will find the link on our FAQs page. I hope this helps.
Last edit: 13 years 3 months ago by sozzled.
13 years 3 months ago #147810 by simontv21
I have Joomla 3 and today I noticed that an update was available for Kunena 3.I let it run the update and now after it sucessfully completed, my site only gives 404 errors.
Luckily, I can access the back end admin pages. Turning off Kunena does not fix it.
tvcentury21.com
help!
13 years 3 months ago - 13 years 3 months ago #147814 by sozzled
G'day, simontv, and welcome to Kunena.
I do not think this is a defect with K 3.0.2. I think this is a Joomla menu issue on your site. I have moved your topic to a different category.
When you installed K 3.0.2, did you follow the installation instructions - did you see the video tutorial in the installation guide that explains how to setup your Kunena menu?
There are also many other topics in the forum that help with problems people have with setting up Kunena to work with their Joomla menu. They are in this category where I have moved your topic and they are "stickied". There are also articles in the Wiki that relate to Kunena "menu issues" . I hope this information helps.
For your information, 99% of "HTTP 404 errors" in Joomla are caused by wrongly-configured menu items.
13 years 3 months ago #147816 by xillibit
Can-you put here please your Kunena report configuration settings ?
13 years 3 months ago #147818 by simontv21
I tried to post settings, but when I hit submit, I get a 500 error on this forum.
Time to create page: 0.155 seconds
