Sticky K 3.0 Kunena menu issues
- 9themestore
- Premium Member
If you can PM me the back-end account, I can help you check it. Please send me via [email protected] email account.
Regards
- 9themestore
- Premium Member
I tried to change the menu title on my local and it was working fine. I think, just appeared on your site. If you want to help you should share your site information.
Regards
Regards
Okey...
Website : www.footballtricksonline.com
Forumin : www.footballtricksonline.com/index.php/es/forum/index
User: tester
Password: tester
If you make any changes in kunena menu item, you will see the entire menu will disappear...
sometimes you have to check in other browser to confirm it.
If you are having problems then, for your own benefit, it would save us all a lot of time if you would kindly post your configuration report when you ask for help from this forum. If you do not post your configuration report we will not ask you for it but you will probably not get your problem solved, either.guidofto wrote: ... any tips? :pinch:
