Sticky K 3.0 Kunena menu issues
- Please read the rules for posting in the Kunena 3.0 Support (reporting defects)
- Please explain where the "list" comes from. Is this something you can see here, on this website ?
- What is the defect in Kunena? Perhaps you are not using the latest version of Kunena? Perhaps you are using a third-party SEO tool? Perhaps you are not using the latest version of Joomla? Perhaps you have made custom changes to your .htaccess file? Perhaps this problem has nothing to do with Kunena at all?
- How can you demonstrate that this problem is a defect in Kunena that is used (without problems) on hundreds of thousands of websites around the world today?
- If you have implemented Joomla SEO correctly, the URLs on your site are generated by the Joomla menu item alias names.
I am using easy front end SEO joomla extension and my kunena and joomla are most updated versions.
I just want to get rid of the issue mentioned in the earlier post. thanks sozzled for the guide.
Link: www.kunena.org/forum/kunena-3-0-support/...e-end-of-kunena-urls
hi ...
Today i checked my google webmaster account which shows too many URLS marked as "NOT FOUND"..when I click those URLS, they give the message, "You do not have permissions to access this page", I think googlebot also does not have permission to access those URLS thats why returned them with not found error....
How can I remove the word "LIST" from the end of these URLS so that they may b accessible by googlebot.
thanks in advance
Please contact the developers of Easy Frontend SEO and ask them why your URLs have "list" in them.aslamshah wrote: I am using easy front end SEO joomla extension ...
- You have not demonstrated any examples of your problem.
- You have not shown how this is relates to Kunena in any way.
- We have no understanding of how Easy Frontend SEO works and it may be worth reading Kunena and SEO: Why would I need ANY third-party SEF plugin? . We do not recommend any third-party SEO products and we do not endorse their use.
- It is also a good idea to read the category description before you post your messages on this forum. The category description is there to give you helpful advice before you post messages on this forum. If you read the category description it will save you time and may give you some ideas how to improve the quality of the responses that you get.
Good luck.
- whitetiger
I've installed the last version of Kunena in the last version of Joomla.
In J. there is a Kunena Menu but empty.
I've created in the Main Menu a item to point a Kunena Home Page and a "left" module associated to Kunena Menu and to the item in the Main Menu.
When I open the page I see the forum home page, but I don't see the Kunena Menu on the left, neither the tabs menu in forum.
Where I wrong?
Thanks in advance
Yes, this is a fairly common question and I have merged your question in this topic that discusses the various problems that people have.whitetiger wrote: I'm sorry if this is a frequent question, but I don't find a solution.
I assume that you mean K 3.0.5, yes?whitetiger wrote: I've installed the last version of Kunena ...
I assume that you mean J 3.3.1, yes?whitetiger wrote: ... in the last version of Joomla ...
Would you like us to see what you see, too?whitetiger wrote: When I open the page I see the forum home page ...
I understand that you want to create a custom menu so that it displays on the left of yoru forum pages. While this not a difficult thing to do, it requires understanding of how the Joomla menu system operates. The Joomla menu system is one of the most difficult parts of Joomla to operate properly.whitetiger wrote: ... I don't see the Kunena Menu on the left ...
There is a guide in the Wiki that shows people how to create custom menus; see Customised menus .
However, before you consider creating a custom menu, you may want to verify that the standard Kunena menu works properly on your website. This website here, at www.kunena.org , uses the standard Kunena menu. Are you able to use your forum with the standard Kunena menu? If you require more assistance, please reply and it may be a good idea to watch the video vimeo.com/69818669 to include details about your website that will help us to diagnose why your installation of Kunena is not working the way that you want it to.
