Question Login Problem
15 years 6 months ago #96033 by nevrastenek
Replied by nevrastenek on topic Re: Login Problem
well done :)
I need to set CB login for new registration for some reasons.
now I'm going to stress joomlapolis :) ;)
many many thanks
15 years 6 months ago #96035 by sozzled
Replied by sozzled on topic Re: Login Problem
nevrastenek wrote: now I'm going to stress joomlapolis :) ;)
No, I think the problem lies with K 1.6.4. We will look at a solution from the Kunena end. :)
15 years 6 months ago #96072 by viper_iii
Replied by viper_iii on topic Re: Login Problem
Believe I have the same issue but not sure...
When logged out and hit reply...
Get redirected to Thread Start...
Login Again
Get redirected to Forum Start
Login Again and now it works...
It also works from the Board Index but cannot login at the thread level or reply to thread level...
CB1.4 as well and almost fully updated...1.6.4 modules needed next. (just edited a few colors on the default template... can't find the line to edit the blue #ktop line color though!)
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 20M
Joomla default template details : rt_chromatophore_j15 | author: RocketTheme | version: 1.5.2 | creationdate: 03/29/08
Third-party components: CommunityBuilder 1.4 | UddeIm 2.2
Modules: Kunena Latest 1.6.2
15 years 6 months ago #96721 by golden0
Replied by golden0 on topic Re: Login Problem
Hi
Think that I have the same problem
Login is only available from index or recent topics - & not the main screen of a specific forum - it just ignores the login and displays Hello Guest like you never hit enter!
Also if you ask for a password token it generates one and then says it is invalid!
It used to work up to about 5 days ago & then it stopped - as far as I know I didnt change anything at all - although a long time ago a user had a weird complaint that may just be the same
I was on an old version then u/g to 1.6.2 that was OK for months until last week - tried adding 1.6.4 - same problem
What other info would you guys need?
Any ideas?
15 years 5 months ago #96726 by golden0
By the way - not using CB - this is a simple Kunena install on J1.5.23 + standard Kunena template
15 years 5 months ago #96735 by sozzled
G'day, golden0, and welcome to Kunena.
golden0 wrote: By the way - not using CB - this is a simple Kunena install on J1.5.23 + standard Kunena template
Then please do not use this category to discuss your problem. This topic is for people who have stated that they use CB. I can confirm that there is a problem with K 1.6.4 and the CB login integration but I do not know whether this is a Kunena problem, a CB login module problem, or an issue with the way that I have setup my test site.
Let's establish exactly what is the cause of the problem, please.
Can you please start a new topic in the Support category and make sure that you include your unedited K 1.6 configuration report. Can you also please show us the exact steps that you follow that give you the problem on your site. Thank you.
We may have further questions for you.
Time to create page: 0.159 seconds
