Question Login Problem
15 years 8 months ago #88470 by UdoZ
Login Problem was created by UdoZ
i'm using Kunena with Community Builder (both the newest versions) on Joomla 1.5. Forum integrations are set properly; SEF/SEO in use.
Problem:
The user login through Kunena only works if the forum is opened via Index or Recent Topics.
It does not work if a logged out user is redirected to the Kunena login form after hitting Reply oder Quote to post a reply.
Any ideas?
Udo
15 years 6 months ago - 15 years 6 months ago #95898 by nevrastenek
Replied by nevrastenek on topic Re: Login Problem
I was confident of solving the problem by installing Kunena 1.6.4 but nothing has changed ...
The problem is that described by UdoZ
my config
joomla 1.5.23
Kunena 1.6.4
CB 1.3.1
SEO Friendly URLs yes
SEO mod_rewrite yes
SEO Add suffix to URLs No
. htaccess enabled
I have no idea to solve. Please help me.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0 | creationdate: 12/26/07
Kunena default template details : Aphotic | author: snilloconator | version: 1.6.0 | creationdate: 2010-23-09
Third-party components: CommunityBuilder 1.3.1 | UddeIm 2.1
Modules: Kunena Latest 1.6.0-RC2
Last edit: 15 years 6 months ago by sozzled. Reason: Reveal K 1.6 configuration report in message
15 years 6 months ago #95901 by xillibit
Replied by xillibit on topic Re: Login Problem
Fireboard 1.6.4 doesn't exit and this has never existed in fireboard
15 years 6 months ago #95904 by nevrastenek
my mistake.... corrected
15 years 6 months ago - 15 years 6 months ago #95907 by sozzled
Replied by sozzled on topic Re: Login Problem
I am sorry that no-one has replied to UdoZ's question asked two months ago. Either UdoZ has fixed the problem or has decided that it was not that important. However someone might have been able to answer the problem better if UdoZ had read the posting guidelines printed at the top of this page and provided us with his/her K 1.6 configuration report.
Setting up SEO is not only a matter of clicking two radio buttons in the Global Configuration panel. That's the easy part. Setting up Joomla SEO also means that you have to have a working .htaccess file, too. The Search Engine Optimisation (SEO) guide in the Wiki explains what you need to do.
Before anyone can attempt to diagnose and recommend a solution in either of the two cases reported in this topic, we need to see the K 1.6 configuration report. If people don't want to provide their report, that's fine ... but we also may not be able to give you much help, either.
The following user(s) said Thank You: nevrastenek
15 years 6 months ago - 15 years 6 months ago #95911 by nevrastenek
will verify another time my .htaccess but this is the only very little problem
Last edit: 15 years 6 months ago by nevrastenek.
Time to create page: 0.153 seconds
