Question Login Problem
- nevrastenek
- Junior Member
When I looked, you could not even see the Recent topics unless you were already logged in. I've changed the menu back the way it should be.UdoZ wrote: Hi,The user login through Kunena only works if the forum is opened via Index or Recent Topics.
Try it now. See if I've fixed the problem. I was able to login to your site, from the Kunena forum page, using the username/password and I did not get logged out.
- nevrastenek
- Junior Member
UdoZ wrote: It does not work if a logged out user is redirected to the Kunena login form after hitting Reply oder Quote to post a reply.
the issue is when you are not logged in and you try to reply or quote a message.
when you are not logged in and reply a message you are correctly redirected to the login but don't work.
In this forun when i try this i'm redirect to the login and after i can reply to a message
I don't know if i have correctly explained the issue... sorry for my english
I've been able to reproduce the situation on one of my test sites. I'll report the matter to the project team and we'll see what needs to be done to fix it properly. Thanks for finding this bug.
