Question [Merged topic]K 1.7.1 and Jomsocial Activity Stream
14 years 8 months ago #117667 by erkan
sozzled wrote:
erkan wrote: And now you are forcing my to update from a working Kunena 1.7.0 to 1.7.2 because of Joomla 2.5 support.
No. That is not true. J! 2.5.0 contained some serious problems that affected hundreds (thousands?) of Joomla extensions. J! 2.5.1 has been released to fix those problems.
The problems that are being discussed in this topic affect the JomSocial Activity Stream. I don't know anything about JomSocial (or the JomSocial Activity Stream). Sorry, I can't help with those things.
So I can still run Kunena 1.7.0 (which works good with Jomsocial) if I have Joomla 2.5.1?
14 years 7 months ago #118632 by triscoe
PIC wrote: As I said, I wouldn't expect Kunena to help me with template problems.
This issue is unrelated to the template and is related to user permissions. You must set all the Kunena categories to "user groups" instead of "access level". Kind of strange because before the upgrade it wouldn't work on "access level, so it was set to "user groups". So I guess the update has switched which permissions setting doesn't work.
Thank you for this, been pulling my hair out to find a solution and here it is. Maybe this should be published somewhere or pinned as a known solution if the activity stream is not showing up in J!2.5 and K.1.7 and Jomsocial 2.4?
14 years 7 months ago #118634 by erkan
The problem for me is that I have to have the Kunena categories set to access levels, I can´t set them to user groups. If I do that my site won´t work as it should.
Time to create page: 0.255 seconds
