Solved Easyblog avatar integration
10 years 10 months ago #171865 by juliengrano
Wow thats a fantastic news Ruud and yes I would be happy to be the tester.
Regarding API I have asked to Stackideas directly to provide me the info but could you have a look in their doc maybe you could find something:
stackideas.com/docs/easyblog/administrators/welcome
It is a pity that you do not like Easyblog, I personnally love it.
The number of functionnalities you can get from Easyblog are tremendous!
I'm an active users of all Stackideas components since 2012, I have helped a lots of french companies choosing and sugggesting this solution because of reactivity, functionalities and performance you can get from those components....
May I know what you dislike from Easyblog?
Can't wait we start woorking on this project! ;)
thx so much!
10 years 10 months ago #171866 by Josh
Replied by Josh on topic Easyblog avatar integration
While I personally use EasySocial for my profile system, would be good to see EasyBlog supported. B)
10 years 10 months ago #171876 by juliengrano
Hi PLease find answer from Stackideas CEO
10 years 10 months ago #171878 by ruud
Replied by ruud on topic Easyblog avatar integration
okay setup an empty plugin (the easy part :)).
Because Easyblog does not have a documented API, I have to 'reverse' engineer things.
I can only do that on a joomla development site that has Easyblog installed.
I have an old 'abandoned' Easyblog Joomla site that I can use for this purpose, only thing is that this is a 3.9.x version of Easyblog.
So question is: has the API changed functionally between those versions? If I develop with 3.9.x Easyblog functions and methods, will it also work in newer versions?
sharing = caring
10 years 10 months ago #171879 by juliengrano
Hi rudd please provide me your email in order for me to provide you necessary and up to date document in order to work on this correctly
10 years 10 months ago - 10 years 10 months ago #171880 by ruud
[cloaked] :evil:
sharing = caring
Last edit: 10 years 10 months ago by ruud.
