Solved Easyblog avatar integration
10 years 10 months ago #171570 by juliengrano
Hi team,
i would like to know as Easyblog is becoming the leader for blog in joomla i would like to know how to setup easyblog avatar to be displayed in kunena forum? (post and profil)
thank you very much
10 years 10 months ago #171609 by bizzomephisto
there is a way to do it, but it is sort of a silly workaround
youll have to use EASYPROFILE
www.easy-profile.com/
go here stackideas.com/forums/easyprofile-integration and scroll to the second to last reply from the developer of easyprofile... he explains how to get the avatar from EASYBLOG
EasyProfile has integration with Kunena already and should allow the 3 to talk to each other.
hope this helps!
10 years 10 months ago #171668 by juliengrano
thank you but instead of installing a new component I would prefer to use directly the internal avatar configuration in Kunena.
Is there anyone from Kunena team that could give me some ideas on how to do it?
I'm sure there are a lots of easyblog users that would love to know about this
Thank you and happy new year!
10 years 10 months ago #171670 by 810
Replied by 810 on topic Easyblog avatar integration
github.com/Kunena/Kunena-Forum/pull/3494/files
this one is done for easyprofile, only you need to edit it to easyblog, you could also ask the author of easyblog, if they can create a plugin for kunena.
10 years 10 months ago #171808 by juliengrano
this is their answer: it is not their priority, at the moment.
As explained, EasyBlog is becoming the number 1 in joomla blogging system so It would be great to get this in native in Kunena.
Get the possibility to choose easyblog avatar because , in my club, a lot of Joomla users using Easyblog do not want to install Kunena as Forum because they can't display Avatar from Easyblog and prefer to stick with easydiscuss which is more a ticketing component instead of a nice forum such as Kunena.
I'm sorry i'm not a developper and do not know how to use this documentation.
What do you think?
10 years 10 months ago #171841 by ruud
Replied by ruud on topic Easyblog avatar integration
not a huge fan of easyblog myself but I am willing to give a shot at the avatar integration plugin (because I like Kunena so much :)).
I created the easyprofile plugin, so should be able to also do easyblog avatar integration.
What I need is the api documentation for easyblog (avatar reading part) and a tester.
@Julien, can you assist?
sharing = caring
The following user(s) said Thank You: Josh
