- Thank you received: 1425
Solved Easyblog avatar integration
- juliengrano
- Junior Member
Fatal Error was detected!
The error was detected in the Kunena - Easyblog Plugin.
Fatal Error: Class 'EB' not found in plugins/kunena/easyblog/avatar.php on line 31
For support click here: Kunena Support
Go back
strange on my test site it always loads EB class, that's why I skipped loading it...
new version (0.0.1) below that will load class EB if not loaded
office.onlinecommunityhub.nl/owncloud/in...hp/s/lZjPySQCd8oPMLi
#fingerscrossed
sharing = caring
- juliengrano
- Junior Member
Hi, sorry about that, could you retry? updated previous messages with new linkjuliengrano wrote: Thx Ruud but it seems we can not download the file from the link you just provide
sharing = caring
- juliengrano
- Junior Member
500 Internal Server Error
The error was detected in the Libraries.
Fatal Error: Maximum function nesting level of '100' reached, aborting! in libraries/joomla/factory.php on line 145
Go back
I have try to increase xdebug.max_nesting_level but still same issue?
