Solved Easyblog avatar integration
10 years 10 months ago #171944 by ruud
Replied by ruud on topic Easyblog avatar integration
hi,
some questions and requests.
could you ask the easyblog team what file needs to be loaded to enable the EB class?
currenty I include_once the include\easyblog.php file.
Do you have a test environment that I could have access to (ftp)
The plugin was downloaded multiple times, are others also seeing this 500 error?
sharing = caring
10 years 10 months ago - 10 years 10 months ago #171947 by ruud
juliengrano wrote: Fatal Error: Maximum function nesting level of '100' reached, aborting! in libraries/joomla/factory.php on line 145
Go back
I have try to increase xdebug.max_nesting_level but still same issue?
Here is some more info that might come in handy. They advise to disable xdebug altogether?
stackoverflow.com/questions/8656089/solu...-of-100-reached-abor
Also in the back-end of the plugin there are two settings, one for the avatar and one for the profile link.
To find out to which one the error is related, could you toggle:
avatar = yes, profile = no > test
avatar = no, profile = yes > test
avatar = no, profile = no > test
to find out in what function the error is (avatar or profile).
sharing = caring
Last edit: 10 years 10 months ago by ruud.
10 years 10 months ago #171994 by juliengrano
I'm sorry I can get it works it always for all option show me the nesting level problem I have followed your link but still it is not working...
Maybe in production and not in local (wamp server) it will work.
10 years 10 months ago #171995 by juliengrano
It is working now! with a new and fresh install your plugin WORK as a charm! thank you very much Ruud!
10 years 10 months ago #171996 by ruud
Cool :woohoo: are there others who can conform (Josh)?
sharing = caring
10 years 10 months ago - 10 years 10 months ago #171998 by juliengrano
Before and after activating the Ruud plugin
Last edit: 10 years 10 months ago by juliengrano.
