Sticky Upgrade problems with K 1.x -> K 2.0.3 (and solution)
13 years 11 months ago #137709 by Mantaii
Hi!
I have searched the forum and can't find an answer so my last attempt is to post here.
I upgraded to the latest version of Kunena and now get the screen shot attached. I've done a recount and sync via the configuration panel and still nothing shows.
The report log is also found below:
Legacy mode: Enabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 240 seconds | Max execution memory: 64M | Max file upload: 16M
Joomla default template details : TK2 | author: JoomlArt.com | version: 1.2.0 | creationdate: 12/26/07
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.3 | creationdate: 2012-11-24
Kunena version detailed: Kunena 2.0.3 | 2012-11-24 [ Reconciliation ]
Plugins: None
Hope someone can help as my website is currently offline until I fix this.
The topic has been locked.
13 years 11 months ago #137718 by sozzled
Here are a couple of thoughts that may help:
(1) Your configuration report shows that you have the System - Legacy plugin enabled. Please see the following information that discusses this issue >>> here <<<
(2) Your configuration report shows that you are using a Joomla site template that is very old; it was designed in December 2007 and it probably does not work in J! 1.5.26. I suggest you should use a more modern template or try using one of the default templates that comes with J! 1.5.
(3) Your configuration report shows some issues with the way you have setup your Joomla menu. I suggest that you read How do I restore my Kunena menu? on our FAQs page.
(4) We cannot actually see your website. When I tried to visit it, I see the message "6 DEC - It'll soon be Christmas!! Maybe even before I manage to get this website back up and running!!!" This is not very helpful to others who may want to look at why your forum is not working properly.
(5) What version of Kunena were you using before you upgraded? Did you see the topic Kunena 2.0.3 known issues and does this apply in your case?
(6) Your configuration report shows that you have some special settings for the way that you're trying to run your "Recent Topics" menu item. It may be useful to try restoring your configuration settings back to their original default values to see if this helps (in the first instance) to resolve your problems. Do you require help in doing that?
13 years 11 months ago #137727 by gertk
Mantaii wrote: Hi!
I have same issue...wating for a fix :blush:
13 years 11 months ago #137730 by rich
Please read the second message in this topic.
The following user(s) said Thank You: gertk
13 years 11 months ago #137773 by gertk
Thanks! It worked with the SQL update!
13 years 11 months ago #137806 by Mantaii
SQL update fixed it for me as well.
Cheers,
Time to create page: 0.189 seconds
