Sticky Upgrade problems with K 1.x -> K 2.0.3 (and solution)
- the_target
13 years 11 months ago #137591
by the_target
Replied by the_target on topic Upgrade problems with K 1.x -> K 2.0.3 (and solution)
Problem confirmed. 1.7.2 upgrade to 2.0.3 is a wreck. Thank goodness for Akeeba backup. Waiting for another version or two to mature at this point.
The topic has been locked.
13 years 11 months ago #137596
by Matias
Replied by Matias on topic Upgrade problems with K 1.x -> K 2.0.3 (and solution)
We are currently investigating the problem, but we are not quite sure what causes it.
There's a bug report in GitHub at: github.com/Kunena/Kunena-2.0/issues/1220
When fix is being made, that is the first place to look into.
13 years 11 months ago #137597
by regdomain
Replied by regdomain on topic Upgrade problems with K 1.x -> K 2.0.3 (and solution)
Probbaly it is problem with 1.7.2 to 2.0? Could anyone provide with 1.7.3 copy?
13 years 11 months ago #137600
by Matias
The issue is more likely in Kunena 2.0 topics migration which had a fix in Kunena 2.0.3.
After quickly looking into your screenshot -- please make sure that plugin called "Kunena - Joomla integration" is enabled.
13 years 11 months ago #137627
by Matias
I found a fix for this issue (needs basic SQL skills):
1) Make backup
2) Go to phpMyAdmin or similar tool and run the code from below (change both #__ to your database prefix):
3) Go to Kunena backend >> Forum Tools >> Recount Statistics and run the action without changing any parameters.
PS. This bug is only present in Kunena 2.0.3 and can be avoided by upgrading first to Kunena 2.0.2.
PPS. It's already fixed and the fix will be in the next version.
1) Make backup
UPDATE #__kunena_topics AS tt
INNER JOIN (
SELECT thread, MIN(hold) AS hold FROM #__kunena_messages WHERE hold IN (0,1) GROUP BY thread
) AS c ON tt.id=c.thread
SET tt.hold = c.hold
WHERE tt.moved_id=0
The following user(s) said Thank You: regdomain
13 years 11 months ago - 13 years 11 months ago #137642
by regdomain
Solution works
Last edit: 13 years 11 months ago by regdomain.
