Question How to deactivate the recaptcha function completely?
13 years 10 months ago #139770 by sozzled
Your settings are
CB for forum access.and Joomla (choose one or the other)
CB for private message and uddeIM (choose one or the other)
CB for user profiles and Kunena (choose one or the other)
CB for login.and Joomla (choose one or the other)
Now do you see why things could become problematical? Your site settings are confused. You need to "un-confuse" things.
13 years 10 months ago #139773 by Aviator
OK, i changed the settings again, please have another look at the config:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 200M
Joomla default template details : rt_metropolis | author: RocketTheme, LLC | version: 1.0 | creationdate: November 1, 2012
Third-party components: CommunityBuilder 1.9 | UddeIM 2.8
Plugins: None
13 years 10 months ago #139779 by rich
You use maybe yet another Captcha plugin? There are some, which can be integrated in Kunena. Independent what are the Captcha settings in Kunena.
Is this not the case, then I know nothing more. :(
13 years 10 months ago - 13 years 10 months ago #139784 by sozzled
I agree with rich. Perhaps you have installed some other CAPTCHA plugin that is not affected/controlled by the Kunena configuration settings.
I looked again at the integration plugin settings (in your configuration report). According to the current settings, your current settings effectively say "don't use Community Builder avatars" and "don't use Kunena avatars". If that's what you want then that's OK. Your forum will not display any avatar images under those circumstances.
Last edit: 13 years 10 months ago by sozzled.
13 years 9 months ago #139833 by Aviator
Hello rich, hello Sozzled,
yes, it is intended not to show any avatar in the forum. We do not need the avatars.
I assume, the other settings are "non-confused" now ? ;)
I had a recaptcha Plugin installed in Joomla, but i knew this and had deactivated this plugin. To be sure that it can not have any effect on Kunena in spite of its deactivation, i deinstalled this plugin completely. But sorry, you guess the answer: the kunena recaptcha is still there.
It seems to me that we have reached the very end of possibilities in this case. Perhaps i can force the recaptcha to get out of work by making a small hack in the source code ? IF possible, please give me an advice how to do this.
Thanks for your efforts.
13 years 9 months ago #139836 by rich
You have uninstalled the right plugin? There is also a plugin "Captcha - ReCaptcha", which is a part of Joomla and has no effect to Kunena.
Time to create page: 0.150 seconds
