Question How to deactivate the recaptcha function completely?
i have installed Kunena 2.0.3 on an intranet website basend on Joomla 2.5.8.
I do not need the recaptcha function, which is buildt in into Kunena. I would like to completely deactivate this feature, but cannot find any manual how to do this. I have looked this up in this forum and on Google, but no reliable results.
If i do not enter a recaptcha key in the backend of kunena, a forum user gets the message, that the key is not configured properly and he can not create any new entry in the forum.
If i enter a recaptcha key, which i have generated in my Google Account, then a forum user can create a new entry but has to deal with the recaptcha form. After having submitted the first entry, then this user can create more entries without the recaptcha form. Important to note: The threshold value for the recaptcha in the "captcha configuration" section in Kunena backend is set to 0.
Any help with this issue is appreciated.
Thank you and regards
Thomas
- Thank you received: 2545
You have also set "CAPTCHA Challenge for Guests = No"?The threshold value for the recaptcha in the "captcha configuration" section in Kunena backend is set to 0.
yes, correct. This is set to No.
Thomas
Thomas
Don't worry, any sensitive information is only visible by Kunena.org moderators.
