Question How to deactivate the recaptcha function completely?
13 years 10 months ago #139513 by sozzled
This does not make any sense to me. According to your configuration report, the forum settings should work perfectly well. However, some of yourKunena integration plugin settings do not look right to me.
These are your Kunena integration settings (extracted from your configuration report earlier):
I have highlighted in different colours the three areas that seem (to me) to conflict. I don't have any other suggestions at this time.
13 years 9 months ago #139697 by Aviator
Hi sozzled,
i checked the items and played around with some different settings. Everything seems to be the best as it is. Only the Kunena Avatar and the Login in Kunena is disabled now, because this is normally done via the Community Builder Log In.
Finally this issue seems to remain unsolved. As soon as you have an idea how to deactivate the recaptcha function please post here.
Thank you.
13 years 9 months ago #139714 by sozzled
Aviator wrote: i checked the items and played around with some different settings. Everything seems to be the best as it is.
Can I see your changes, please (post your updated configuration report). I will not know any more until we have made sure that your configuration is the best that we can make it, as a place to start.
Please note, K 2.0.3 is not supported and you should immediate upgrade to K 2.0.4. If you choose to not upgrade, that's OK but we will have to close this topic if that is your choice.
13 years 9 months ago - 13 years 9 months ago #139716 by Aviator
Sorry, i get this error in your forum now when trying to answer your post:
Internal Server error 500
EDIT: OK, this post was accepted, then i will try now with the config report ....
Last edit: 13 years 9 months ago by Aviator.
13 years 9 months ago #139717 by Aviator
Sorry, when trying to submit the config report i get this error in your forum:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [email protected] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
13 years 9 months ago #139718 by Aviator
What shall i do now ? :unsure:
