Sticky Before you post your question, read this first
14 years 4 months ago - 10 years 7 months ago #127255 by sozzled
The information in this topic applies to all versions of Joomla.
Before people write to us to tell us about their problems, they should first: People should pay particular attention to key messages contained in the release notes, for example:
People should also be familiar with the FAQs menu tab at the top of this page.
We also ask that, before you post in the forum, you look at the sticky topics (like this one) in which your question may have already been asked and answered.
We understand that many people may experience one or a number of the following problem symptoms:
  • You cannot see the BBcode toolbar to insert Kunena BBcode.
  • You get the message "Loading BBcode editor..." but no BBcode toolbar appears.
  • You cannot edit your Kunena user profile including setting your forum preferences, avatar image, etc.
  • You cannot use the Quick Reply feature and, in some cases, the Quote feature.
  • You cannot use the expand/collapse feature used on various sections of Kunena pages
  • You cannot use the Smiley selector to insert emoticons into Kunena messages.
  • You cannot use the Kunena user ban features.
  • You cannot see, in your user profile, the messages you posted.
  • You cannot use the image lightbox view feature.
  • The Attachments "Add File" button does not let you browse files on your computer.
Most of these problems occur because websites do not meet the Technical Requirements . In most cases, people have installed Kunena after they've installed everything else or after upgrading frm an older version of Kunena (and, therefore, other installed software already exists).
Many of these problems have been discussed at one time or another and were collected in the so-called " great Moootools/Javascript discussion ". That topic became unwieldy and difficult for people to find the answers they were looking for. We reviewed that topic and analysed the causes of the various problems that people were having.
Even though we expected that most of those problems would disappear when J! 1.5 was finally retired, the same old problems resurfaced again in J! 1.6, J! 1.7, J! 2.5, J! 3.0, J3.1 and even in J! 3.2 and they show no sign of going away because other Joomla extension developers have written their own software that does not nicely co-operate with Joomla. :whistle:
Last edit: 10 years 7 months ago by rich. Reason: Links corrected
The following user(s) said Thank You: mraab, donkey12, cavusoglu28, vincebodie, niny22, jpfrancoeur, bizzymate, mehdee4 and 5 other people also said thanks.
14 years 4 months ago - 14 years 4 months ago #127334 by NickJWStone
After upgrading my recently installend 1.7.2 version to 2.0 the submenu's (tabs) are not working (for instance in profile). New users cannot acces the tabs to upload avatars etc.
Any clue how to solve this issue?
Joomla 2.5.6, Kunena 2.0.0, LSC
Last edit: 14 years 4 months ago by NickJWStone.
14 years 4 months ago #127338 by sozzled
G'day, Nick and welcome to Kunena.
Please see msg #1 in this topic.
14 years 4 months ago - 14 years 4 months ago #127359 by Adrenaline22
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : ammon | author: RocketTheme, LLC | version: 3.2.8 | creationdate: August 1, 2011
Kunena default template details : JF Corporate | author: JoomForest | version: 1.0 | creationdate: 01.05.2012
Kunena version detailled: Kunena 2.0.0 | 2012-06-27 [ Diplomatia ]
| Kunena detailled configuration:
| Joomla! detailled language files installed:
Plugins: None
The usual 'turn Build title spans to off' solution doesn't work I'm reaching out to the devs for help. I have tried many forums with bridges and so on, but finally opted for Kunena because is a Joomla component afterall and not some separate software. I really want this to work. Please help :(
Peter
Last edit: 14 years 4 months ago by Adrenaline22.
14 years 4 months ago - 14 years 4 months ago #127383 by NickJWStone
Hi Sozzled,
thanks for your reply. I managed my way through the javascript/mootools conflicts, but this doesn't seem to help me further. I had some problems before with (1.7.2) but managed to fix that. Now with the upgrade I've some different issues which I cannot fix out of these 'guidelines'.
Even when I change my template to a Joomla default template, these tabbed menus do not work. Everything worked fine with 1.7.2.
I hope some of you can help me out!
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 256M | Max file upload: 32M
Joomla default template details : rt_clarion | author: RocketTheme, LLC | version: 1.0 | creationdate: February 10, 2012
Plugins: Content - Kunena Discuss 2.0.0
Modules: Kunena Latest 2.0.0
14 years 4 months ago #127394 by sozzled
NickJWStone: Even without logging in to your website, I can see that you have still have Javascript problems. For example, the toggle buttons to expand or collapse various sections on the Kunena pages does not work.
What would you like us to do for you that has not already been discussed in My Joomla site template makes a mess of Kunena ? You have a choice: either something you are using on your website is more important to you to keep than to have a working Kunena forum or you need to remove whatever it is that is preventing you using the full capabilities of Kunena.
We know that the Kunena configuration report does not list "everything" on a user's website. There are other tools that produce lists of "everything" but I hesitate to recommend them because the reports that they produce also contain much confidential data that would be unwise to display in a public forum. No doubt, if we knew "everything" about your website we could probably tell you, in 2 seconds, which thing(s) you need to remove in order to get Kunena working again properly. Unfortunately we do not know everything about your website and we cannot know everything unless we spend as much time as you have already spent examining all your Joomla extensions - your templates, plugins, components, modules - and, one-by-one, remove each until you discover which one(s) are causing the problem.
Time to create page: 0.202 seconds
