Sticky Before you post your question, read this first
14 years 4 months ago #127419 by coder4life
The "Turn build title spans to off" is a Gantry option if I am not mistaken. Please contact RocketTheme ( www.rockettheme.com/ ) for this issue as it is not specific to Kunena.
The following user(s) said Thank You: MarioMari
14 years 4 months ago #127423 by sozzled
Adrenaline22: The answer to your problem is contained in msg #1 of this topic.
14 years 4 months ago #127464 by edilson_w
sozzled,
The following data access to the site:
After clicking the menu access
After login to the site, click on "TIRE SUAS DUVIDAS EM NOSSO FÓRUM"
Since I am grateful for your help, I await answers
Edilson
14 years 4 months ago #127476 by NickJWStone
coder4life wrote: The "Turn build title spans to off" is a Gantry option if I am not mistaken. Please contact RocketTheme ( www.rockettheme.com/ ) for this issue as it is not specific to Kunena.
Indeed I had to turn 'build title spans' off when using 1.7.2 Everything was working fine after that. It seems the update to 2.0.0 brings some new javascript/mootools difficulties. I disabeled all RocketTheme related plugins and switched to a standard joomla template, but still no effect. I will keep on searching for the problem... Any tips are welcome ;)
I appreciate the effort you all put into this, but for the moment I'm lost and consider moving back to 1.7.2
14 years 4 months ago #127494 by sozzled
I spent about 30 minutes looking at your site, edilson_w, and it's difficult for me to figure out what other Javascript library you're loading that clobbers Mootools. I suggest that you read When all else fails, try this . It may help.
14 years 4 months ago #127496 by sozzled
You can "move back" to K 1.7.2 if you want. You need to restore your site from a backup because there is no other simpler downgrade option. Just remember, though, K 1.7.2 will only be supported until 31 Aug 2012. You have a Javascript library conflict that is causing your problem, Perhaps you should try When all else fails, try this ?
Time to create page: 0.155 seconds
