Sticky Before you post your question, read this first
14 years 4 months ago #127503 by edilson_w
I installed Joomla 2.5.6, with no extension after I installed the latest version of Kunena and gave the following error when accessing the forum
500 Internal Server Error
Fatal Error was detected!
Fatal Error: Cannot pass parameter 2 by reference in components/com_kunena/lib/kunena.file.class.1.6.php on line 60
The error was detected in the Kunena Component.
For support click here: Kunena Support
I believe he is having some incompatibility Sun Joomla and Kunena 2.5.6.
14 years 4 months ago - 14 years 4 months ago #127505 by sozzled
edilson_w: Originally your problem occurred in K 1.7.2 and you posted it in If you are having problems with Kunena, please read this first . Since that time you have upgraded to K 2.0.0 (but you omitted to give us that important information).
The "Fatal Error: Cannot pass parameter 2 by reference in components/com_kunena/lib/kunena.file.class.1.6.php on line 60 error" is different! There is a separate sticky topic about that subject. See Fatal Error: Cannot pass parameter 2 by reference in components/com_kunena/lib/kunena.file.class.1.6.php on line 60 .
You still have a Javascript library conflict even with K 2.0.0.
Last edit: 14 years 4 months ago by sozzled.
14 years 4 months ago #127512 by edilson_w
I did another test facility in the Joomla 2.5.6 local server and a new installation Kunena com_kunena_v2.0.0_2012-06-27.
Gave the following error:
But I informed version of Kunena, it was you who moved the topic
I still have the same conflict with K JavaScript library 2.0.0.
14 years 4 months ago #127514 by sozzled
I am not arguing with you edilson_w. The HTTP 500 Internal Server Error is unrelated to the Javascript library issue. The HTTP 500 error is documented in a different topic and there is an answer there, too (around msg #28 of the topic I mentioned in my last reply). You need to deal with the HTTP 500 error.
You have a Javascript library conflict caused by something you have installed on your website. I do not know what that thing is.
14 years 4 months ago #127599 by edilson_w
According to instructions, to discover the error bar BBcode have disappeared and not send more attachment. And as you do not know what caused this problem, so I was directed to install Joomla 2.5.6, with no extension and then go installing Components that have already installed Joomla in which the error occurred with the Kunena, to know which extension is causing the error.
I made installation of Joomla 2.5.6 and after intalei Kunena, create the menu item, and click the menu item to access the page principla forum generated the error:
Gave the Following error:
Recalling that the error in Kunena on my site, occurred after upgrading Joomla 2.5.4 to 2.5.6.
14 years 4 months ago - 14 years 4 months ago #127932 by alsthom
I finally update to K 2.0 and I am really impressed about the SPEED!!!
I noticed some issues when making new posts;
-Add file
-Preview
-quick reply, don't work
Additionaly at the profile page the buttons don't work. I click edit and the all buttons are dead. They aren't "clickable"
Site is www.amnizia.org (click forum; guests can see only two categories....)
Here are my settings.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 100M
Joomla default template details : shadows_iii | author: ThemeKat | version: 1.0.0 | creationdate: May 2012
Kunena version detailled: Kunena 2.0.0 | 2012-06-27 [ Diplomatia ]
| Kunena detailled configuration:
| Joomla! detailled language files installed:
Third-party components: UddeIM 2.8
Plugins: None
Last edit: 14 years 4 months ago by alsthom.
Time to create page: 0.178 seconds
