Sticky Before you post your question, read this first
14 years 3 months ago #130347 by Anglershaven
Okay, I have had some virus issues on my domain and after running antivirus, some scripts have been removed. Ever since then, when clicking on the Emoticon buttons or adding an attachments, nothing seems to happen. The file name is not displayed when selected for upload also the "INSERT" button does not display anymore to insert the Attachments. Clicking on an Emoticon also does not insert anything into the message body. Now I know that this must be related to some scripts being commented out.
I have installed WAMP Server, Jamoola and Kunena and works 100% I can upload files and insert Emoticons. Everything works.
My question is, what files do I need to replace on my domain to fix this. Or is it not that simple?
14 years 3 months ago #130362 by kiwi3685
Anglershaven wrote: .My question is, what files do I need to replace on my domain to fix this. Or is it not that simple?
I'm pretty sure a moderator is going to remind you that you should have started a fresh topic :(
But in response to your question, why mess about trying to find what files need replacing? Surely easier to simply copy a complete set?
14 years 3 months ago #130369 by Anglershaven
kiwi3685 wrote: But in response to your question, why mess about trying to find what files need replacing? Surely easier to simply copy a complete set?
Thanks, will try that, what do I copy? I assume a directory of sorts. Will it not cause setting problems.
14 years 3 months ago #130395 by sozzled
Anglershaven wrote: ... clicking on the Emoticon buttons or adding an attachments, nothing seems to happen. The file name is not displayed when selected for upload also the "INSERT" button does not display anymore to insert the Attachments. Clicking on an Emoticon also does not insert anything into the message body.
Please read msg #1 in this topic. The answer lies there.
14 years 3 months ago #130600 by Sergio Futuro
Hi everybody, I would not be boring, but I can't change avatar in my Forum.
If I edit my profile or user edit profile we can't change avatar.
My Gravatar plug-in is disabled.
Joomla is 2.5.6 and Kunena 2.0.1
Thank you for considering my request
14 years 3 months ago #130763 by xillibit
What's happen when you upload a new avatar ?
Time to create page: 0.146 seconds
