Sticky Before you post your question, read this first
14 years 3 months ago - 14 years 3 months ago #131583 by TheZoker
Hi all,
Today I installed Kunena Forum to my Joomla and tried to change my profil.
But when I click on "Save" nothing happens....
This is the code line of the button:
<button type="submit" class="kbutton ks validate">Save</button>
What is wring?
I changed nothing to the files...
Here is the configuration report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 200M
Joomla default template details : universl | author: Fio | version: 2.5.0 | creationdate: 07.02.2009
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Third-party SEF components: sh404sef 3.5.1.1299
Plugins: None
Thankx
TheZoker
Last edit: 14 years 3 months ago by TheZoker. Reason: Add configuration report
14 years 3 months ago #131616 by sozzled
G'day, TheZoker, and welcome to Kunena.
The save button is driven by Javascript. If there is a Javascript conflict (caused by something you've loaded on your site) with Joomla Mootools (which is needed by Kunena) then certain things (like pressing the save button) may not work. The general advice relating to these problems is contained in msg #1 of this topic. I hope it helps.
The following user(s) said Thank You: TheZoker
14 years 3 months ago #131624 by TheZoker
sozzled wrote: G'day, TheZoker, and welcome to Kunena.
Ok but I`m currently not understanding, how I can find the problem...
Now I know it COULD be something with the mootools, right?
But how I should go on?
14 years 3 months ago - 14 years 3 months ago #131626 by sozzled
TheZoker wrote: Now I know it COULD be something with the mootools, right?
The problem is caused by a conflict between one Javascript library that you're using and the Mootools Javascript library - which is needed by Joomla (and by Kunena) - yes.
TheZoker wrote: But how I should go on?
Read the information given in msg #1 of this topic which provides advice on what you can do. I hope that helps.
Last edit: 14 years 3 months ago by sozzled.
14 years 3 months ago - 14 years 3 months ago #131669 by yigitusta9
hello there is no edit button for profiles please help
website= mcrepublic.net
thanks lot plz help meh
Last edit: 14 years 3 months ago by sozzled. Reason: Hide the site login details
14 years 3 months ago #131673 by sozzled
The answer to your question is in msg #1 of this topic.
Time to create page: 0.170 seconds
