- Thank you received: 97
configuration report
Merged Hide / Disable login
13 years 9 months ago #136647
by TKtemp
Replied by TKtemp on topic Help ! Remove Kunena Default Template Login
13 years 9 months ago #136649
Replied by sozzled on topic Hide / Disable login
*** Topics merged ***
13 years 9 months ago #137077
by Josh
Replied by Josh on topic Hide the Login Form
There should be an option to hide the login form. I looked all around and could not find one. :huh:
As you can see on my site I have a login form at the top: www.alpineascent.com/forum
It seems kinda silly to have it twice.
13 years 9 months ago #137079
by 810
Replied by 810 on topic Hide the Login Form
1) go to backend
2) go to plugins
3) Kunena - Joomla Integration
4) Set Enable Joomla Login to "No"
2) go to plugins
The following user(s) said Thank You: Josh
13 years 9 months ago #137110
13 years 9 months ago #137133
by Josh
Replied by Josh on topic Hide / Disable login
Thanks! I forgot that Kunena 2.0 does a lot of reliance on plugin settings.
Anyways, works just fine. I did not find this thread when doing a search, rather I got stuff about authentication and such.
Time to create page: 0.239 seconds
