Merged Hide / Disable login
13 years 7 months ago #143033 by QuakeLive
Replied by QuakeLive on topic Hide LOGIN form?
Hi :) ,
My website already has (Joomla|!) login module, so I would like to remove login form. I tried to put all Kunena menu items to "Registered" access, but login form is still there.
Is it possible to hide Kunena login form?
Thanks in advance!
13 years 7 months ago - 13 years 7 months ago #143034 by MSHW
Replied by MSHW on topic Hide LOGIN form?
Edit com_kunena/template/your template/html/common/login.php
Last edit: 13 years 7 months ago by MSHW.
13 years 7 months ago - 13 years 7 months ago #143040 by QuakeLive
MSHW wrote: Edit com_kunena/template/your template/html/common/login.php
thank you, but I need to ask what should I do - can I just put all code under comments (under "<!--" "-->"), or I need to change module position from "kprofilebox-right" to something, or I can delete all the code form that file?
Sorry, I don't know PHP :blush: (need to learn)
Thanks in advance!
Last edit: 13 years 7 months ago by QuakeLive.
13 years 7 months ago #143041 by sozzled
Replied by sozzled on topic Hide LOGIN form?
Did you read the topic Hide / Disable login ?
It's really easy and you do not need to know PHP.
A lot of these simple questions can be found by searching the forum topics. ;)
The following user(s) said Thank You: QuakeLive
13 years 7 months ago - 13 years 7 months ago #143042 by MSHW
sozzled wrote: Did you read the topic Hide / Disable login ?
Oh, right. Or that :blush:
13 years 7 months ago #143069 by QuakeLive
Ok, thank you, the problem is solved. :)
