Merged Hide / Disable login
14 years 4 months ago - 14 years 4 months ago #127389 by hangloose.51
1. As it was possible in the last version, I want to hide the login-frame. In the Config, the tab "integration" is missing!
2. I also want to hide the top-frame (.../top-forum) because I don´t need it.
Sure, I can delete it in the code, bit thats no professional solution. Any idees? Did I overlooked somthing?
Thanks for help!
Kunena 2.0.0
Joomla! 2.5.6 Stable
Last edit: 14 years 4 months ago by hangloose.51.
14 years 4 months ago #127411 by sozzled
Replied by sozzled on topic Hide / Disable login
This is now a "how to" question for K 2.0.
To disable the login in K 2.0 make the following change:
Kunena Forum » Kunena Plugins » Joomla Integration » Parameters » Plugin Parameters » Enable Joomla Login = No.
The following user(s) said Thank You: stempelman
14 years 4 months ago #127829 by Mathyas
How do I turn off the login and registration module?
On the K1.7:
A long time ago, in a galaxy far far away,
An old wise computer once said...
00010110010001010001010
14 years 4 months ago #128386 by Mathyas
Nothing answer? :)
I would like to turn off the login module (as K1.7)
14 years 4 months ago #128427 by sozzled
*** Topics merged ***
Mathyas: The answer is in this topic.
14 years 4 months ago - 14 years 4 months ago #128465 by Mathyas
Replied by Mathyas on topic Hide / Disable login
sozzled wrote: Mathyas: The answer is in this topic.
Thanks!
But this method doesn't work :(
Last edit: 14 years 4 months ago by Mathyas.
