Merged Hide / Disable login
14 years 4 months ago #128483 by Mathyas
Replied by Mathyas on topic Hide / Disable login
Do you think about this?
A long time ago, in a galaxy far far away,
An old wise computer once said...
00010110010001010001010
14 years 4 months ago - 14 years 4 months ago #128486 by BadCluster
Replied by BadCluster on topic Hide / Disable login
This is my configuration report:
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 64M | Max file upload: 25M
Joomla default template details : it_community | author: IceTheme | version: 1.7.0 | creationdate: 01 December 2011
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Third-party components: Jomsocial 2.6.2
Plugins: JomSocial - My Kunena Forum Posts 2.0.0
Modules: Kunena Latest 1.7.2
Last edit: 14 years 4 months ago by sozzled. Reason: Reveal Kunena configuration report in message
14 years 4 months ago #128495 by Mathyas
sozzled wrote: According to your configuration report, you have enabled the login in your Community Builder integration settings.
Working! :)
Plug-in Manager: Plug-ins:
Kunena - Joomla Integration/Enable Joomla Login: NO
Kunena - Community Builder Integration/Enable Community Builder Login: NO
Thank you!
14 years 4 months ago - 14 years 4 months ago #128538 by sozzled
Replied by sozzled on topic Hide / Disable login
Mathyas: Thanks for letting us know and sorry it took me so long to figure out the whole answer. There have been several very important improvements in the K 2.0.1 configuration report. All the answers were staring me in my face by looking at the integration settings in your report. It will be a lot easier now to answer this question in future. :cheer:
BadCluster: In your case, you have to make changes in two places (your configuration report actually shows you the two things you need to do).
  • Kunena Plugins » Kunena - Joomla Integration » Plug-in: [Edit] » Parameters » Plug-in Parameters » Enable Joomla Login = No
  • Kunena Plugins » Kunena - JomSocial Integration » Plug-in: [Edit] » Parameters » Plug-in Parameters » Enable JomSocial Login = No
Summary:
For people using K 2.0, and depending on what other Joomla extensions they may have installed (e.g. Community Builder or JomSocial), there are three places where people may need to look if they want to disable the login form at the top of the Kunena forum pages. These are Kunena Plugins:
  1. Kunena - Joomla Integration » Parameters » Plug-in Parameters » Enable Joomla Login = Yes | No
  2. Kunena - CommunityBuilder Integration » Parameters » Plug-in Parameters » Enable CommunityBuilder Login = Yes | No
  3. Kunena Plugins » Kunena - JomSocial Integration » Parameters » Plug-in Parameters » Enable JomSocial Login = Yes | No
The following user(s) said Thank You: Josh, BadCluster
14 years 4 months ago #128744 by BadCluster
sozzled wrote: BadCluster: In your case, you have to make changes in two places (your configuration report actually shows you the two things you need to do).
Thank you! It works perfect!
14 years 4 months ago #128999 by Dhruba RC
Replied by Dhruba RC on topic Hide / Disable login
Many many thanks, the log in window is finally closed for good!
(Could you please mark my thread "Omitting Login Option" as resolved since the topic has been locked and I cannot do that.)
Regards!
Time to create page: 0.169 seconds
