Merged Hide / Disable login
14 years 4 months ago #128468 by sozzled
Replied by sozzled on topic Hide / Disable login
Can we have your configuration report, please, Mathyas? Thank you
14 years 4 months ago #128469 by BadCluster
Replied by BadCluster on topic Hide / Disable login
I've the same Problem!
I've set OFF the integration with joomla
It continue to show me the form BUT it don't permit me to do login!
If you wanna try:
www.giocolieri.org/web/
@Sozzled I've reply about the Integration Tab Missing, I'd like to know the opinion about my suggestion.
www.kunena.org/forum/K-2-0-General-Quest...n-Tab-Missing#127925
14 years 4 months ago - 14 years 4 months ago #128473 by Mathyas
Replied by Mathyas on topic Hide / Disable login
sozzled wrote: Can we have your configuration report, please, Mathyas? Thank you
Yes of course
Here you are :)
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 512M | Max file upload: 200M
Joomla default template details : ict_businessco | author: Mátyás Csaba | version: 1.6/1.7 | creationdate: 2009
Kunena default template details : By Mathyas | author: Mátyás Csaba | version: 1.6.0 | creationdate: 2010-10-11
Third-party components: CommunityBuilder 1.8.1
Plugins: Content - Kunena Discuss 2.0.1
Modules: Kunena Latest 2.0.1 | Kunena Stats 2.0.1 | Kunena Login 2.0.1 | Kunena Search 2.0.1
A long time ago, in a galaxy far far away,
An old wise computer once said...
00010110010001010001010
Last edit: 14 years 4 months ago by sozzled. Reason: Reveal Kunena configuration report in message
14 years 4 months ago #128476 by sozzled
Thank you for your configuration report. Your configuration report shows that you are not using the standard Kunena Blue Eagle template. I suggest you try with the standard Kunena Blue Eagle template.
14 years 4 months ago - 14 years 4 months ago #128478 by Mathyas
sozzled wrote: I suggest you try with the standard Kunena Blue Eagle template.
I did, but no change.
14 years 4 months ago #128481 by sozzled
According to your configuration report, you have enabled the login in your Community Builder integration settings.
Time to create page: 0.175 seconds
